Addco Rsb
Old Oct 26, 2003 | 06:57 PM
portdave's Avatar
Addco Rsb
I finally got around to installing my RSB. Works great. I love the difference but they sent the wrong bolts in my package. I bought this on a group deal through Cattman. I think Mentat had the same problem.
Just thought I would mention that the right size bolt is M12 x 35mm x 1.25 fine thread. I had to go to a few different places to find it. Make sure you get one that is fully threaded.
Wanted to save someone else some time. Hopefully future ones will have the right hardware. Good luck and thanks Lordrandall for the write-up.
David
Old Oct 26, 2003 | 07:09 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
ill have to remember that cause after my motors done ill be doing the suspension.
Old Oct 26, 2003 | 07:24 PM
Jack.'s Avatar
Yeh i'm researching suspension right now, sway bar will come first or last to springs/struts?
Old Oct 26, 2003 | 09:52 PM
KLoWnPR109's Avatar
last in most cases
Old Oct 26, 2003 | 10:34 PM
Jeff92se's Avatar
I'm needing a caw
Do it first and don't look back
Old Oct 27, 2003 | 01:14 AM
davebond007's Avatar
You need to get around to fixing yours.
Old Oct 27, 2003 | 01:29 AM
MrGone's Avatar
dave, your banned
Hmm I wonder if the ST RSB needs it too?
Old Oct 27, 2003 | 07:10 AM
portdave's Avatar
I did my RSB after the springs/struts but others here may have a better suggestion. Just do it all at the same time if you have the money. It sure makes a difference.
I don't know about the hardware with any of the other bars. They just did not put in the right bolts with mine and it was a pain and a lot of wasted time trying to find them at local stores.
Good luck to all doing this mod. Definitely worth it.
David
Old Oct 27, 2003 | 12:04 PM
94M@X's Avatar
Would you guys recomend both front and rear or is rear sufficent?
Old Oct 27, 2003 | 07:16 PM
portdave's Avatar
Not sure on the GXE model that you have but I thought the stock sway bar was sufficient on the SE model.
I think ADDCO only makes the rear sway but I am not sure. Maybe someone else can chime in on this.
Just the rear did the trick for my car. I have a 93 se auto.
David
Old Oct 27, 2003 | 07:32 PM
Jack.'s Avatar
Yeh, i've only seen addco RSB's but Cattman's site has a pretty decent deal on the addco RSB + cattman FSTB for 300. I was thinking if I was to get one, I might as well do both. I've heard a lot of great things about each of them.
Old Oct 28, 2003 | 12:34 AM
Bman's Avatar
Both GXE and SE models have identical front sway bars. SE models have a rear bar some pathetic number of millimeters larger, like 1 or 2mm. Yay.
Old Oct 28, 2003 | 05:42 AM
Sir Nikon's Avatar
Definitely do front and rear struts. I added Tokicos and DAMN... Quite a difference! Very nice.
Old Oct 28, 2003 | 06:29 AM
portdave's Avatar
I got my ADDCO RSB for $122 shipped from Cattman through a group deal about 3 months ago. I got a FSTB for about $45 on ebay (the one for the 2000 model). Don't spend $300 to include a FSTB. Just look for a good deal on the RSB.
David
Old Oct 28, 2003 | 07:27 AM
crsmax's Avatar
ADDCO only makes rear strut bar, Suspension Techniques makes front and rear.
Old Oct 28, 2003 | 08:34 AM
MaDMaX024's Avatar
i removed my stock sway (tore a stock bushing while replacing my rear struts so i decided to put the addco in) first off the bolts were all wrong, they didnt fit the ends, they didnt give me any for the end links. now with my endlinks the drivers side has studs and the passengers has threaded bolt holes! any ideas on how to remove the studs? they're too big to fit the addco's bracket and i broke one.
Old Oct 28, 2003 | 03:38 PM
internetautomar's Avatar
mod or sell?
I handle the addco and suspension tech sway bars. sorry no FSTBs yet.
PM or e-mail me if you wanna know more.
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Ramius83
Oct 19, 2000 09:42 AM
punkdork
Sep 25, 2000 02:49 PM
