How hard is it to install clear corner lenses
Old Oct 26, 2003 | 09:43 PM
harrymay's Avatar
im replacing the corners from www.custommaxima.com, theyre cheaper than i thought.
I wuz just wondering how easy they are to install, well how hard before i go ahead and get them.
Bearing in mind i have never doen any work like this before. if someone could break it down for me.
BTW- I have already done a search
Old Oct 26, 2003 | 09:50 PM
KLoWnPR109's Avatar
open hood, undo screw, take off old, put on new after transferring the harness and enjoy
Old Oct 26, 2003 | 09:58 PM
harrymay's Avatar
do they come in pairs? coz they added two orders when i tried to buy them?
Old Oct 26, 2003 | 09:59 PM
KLoWnPR109's Avatar
Yes, they come in pairs
Old Oct 26, 2003 | 10:00 PM
harrymay's Avatar
thank you very much for your help.
Old Oct 26, 2003 | 10:01 PM
KLoWnPR109's Avatar
anytime...
Old Oct 27, 2003 | 05:05 AM
«§»Craig B«§»'s Avatar
it might be too late now, but check out ebay, you can usually get clear corners for a little cheaper than that
I believe there is something in the online chilton's manual on how to remove the corner lights. Also, check my site (www.prism.gatech.edu/~gte671n/mymax.html) in the how-to section for foglight rewiring and it has some info there too
good luck
Old Oct 27, 2003 | 07:13 AM
jaguax's Avatar
Just to let you know the top part of the corner light is held on by a screw and the bottom part is held on by this snap on ball joint thing. You have to either give it a good pull from the bottom or get a little screwdriver or something and slide it in between the headlight and corner light and just pry it out which makes things much easier.
Also, keep your stock corners because chances are that those cheap corners you buy will start to come apart in the future.
Johnny9595
Sep 3, 2015 05:18 AM
umnitza
Sep 1, 2015 01:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
MikesChevelle
Aug 6, 2015 11:36 AM
