Breather fuel line ... ehgine wouldn't start in moist conditions ...
Old Nov 5, 2003 | 08:33 AM
rrrfoma's Avatar
I replaced 2 fuel lines (high and low) but didn't replace the third one (breather line) and it's all rusty. Might it cause engine not to start in humid/moist conditions?
I have spent an hour trying to figure out why it wouldn't start (and it happens in humid/moist wheather conditions only). When engine is hot or dry conditions - no prob, it starts like a charm.
I'll be replacing distributor cap and rotor, coil and oxygen sensor.
Any other ideas?
PS: maxima is my winter car and it spent almost all the year long in a heated storage
Old Nov 5, 2003 | 08:39 AM
internetautomar's Avatar
mod or sell?
starting with the cap and rotor is your best bet.
Old Nov 5, 2003 | 08:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
if they are a little "vintage" then get new ones...also check wires too.
Old Nov 5, 2003 | 08:52 AM
rrrfoma's Avatar
New wires and spark plugs are already in place.
But back to the original question - could breather line effect it in any way? And what is it for?
Old Nov 5, 2003 | 08:55 AM
mod or sell?
Emissions. To keep the excess gas from disappating into the atmosphere
Old Nov 6, 2003 | 10:35 PM
bvtran's Avatar
94c Big Max
check all of your vacuum lines, esp the big pipe running from the trottle body to the air filter box. Check all of the clamps and sure they're all nice and tight cuz if moisture gets in there, the air sensors will get messed up and won't start the engine.
bvtran's Avatar
94c Big Max
check all of your vacuum lines, esp the big pipe running from the trottle body to the air filter box. Check all of the clamps and be sure they're all nice and tight cuz if moisture gets in there, the air sensors will get messed up and won't start the engine.
Old Nov 7, 2003 | 05:48 AM
rrrfoma's Avatar
I used WD40 to get moisture out and it started right away (I let it stay for about 1 hour, of course - I don't want to call the fire dept.).
I guess rotor and dist. cap are my problem.
Thanx or your input anyway!
homewrecker
Aug 24, 2015 08:56 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
