Hell Yeah!!
Old Nov 12, 2003 | 02:19 PM
mtcookson's Avatar
Hell Yeah!!
I think I found my entire problem to why my engine isn't running!!!!!!!!!! I'm still going to make sure this is the final problem but I'm nearly 100% sure once this is fixed it will run.
Basically, the front manifold wasn't allowing exhaust to go through the exhaust system so only have of the engine's exhaust was being expelled. Once I fix this i'm almost sure it will run. I'll let everyone know the results soon.
Old Nov 12, 2003 | 02:53 PM
Matt93SE's Avatar
STFU n00b!
uhhhhh.....
you leave a banana stuck in it while you were working?
Old Nov 12, 2003 | 02:54 PM
broncoguy's Avatar
Yeah...I'd like to know how that happens...sounds like something that would happen to me!
Old Nov 12, 2003 | 03:37 PM
mtcookson's Avatar
actually, what happened was i had a guy weld on a steel plate to cover the flange the turbo originally bolted to. i though everything was open so it would allow exhaust from cylinders 2, 4, and 6 to flow to the crossover pipe. what nissan actually did was cast the manifold so that the exhaust from the front and rear banks don't meet until the turbo, which would keep turbulence down. so, for now all i have to do is cut off the steel plate covering the flange and make a sort of box so the exhaust can flow through. this will rob power but it will have to do until i can make a manifold for it.
Old Nov 12, 2003 | 03:41 PM
Matt93SE's Avatar
STFU n00b!
do it once. do it right. you'll hate yourself in the morning if you don't.
Old Nov 12, 2003 | 03:43 PM
mtcookson's Avatar
i don't have the proper stuff to do it right now. i need to order a bunch of mandrel bends and other junk. i still need to get some mig wire and some gas for my welder.
i have to fix it at my welding class at the moment. it starts in about 50 minutes.
Old Nov 12, 2003 | 03:46 PM
Matt93SE's Avatar
STFU n00b!
okay, have fun. don't come crying to us when you break something else because you rigged it.
mtcookson's Avatar
i don't think i'll be able to break anything. i'm just redirecting the exhaust.
Old Nov 12, 2003 | 03:52 PM
Matt93SE's Avatar
STFU n00b!
suuuuuuuuuuuuure.
Old Nov 12, 2003 | 04:01 PM
mtcookson's Avatar
well, i guess there is always the chance of cracking the manifold while welding since its cast iron.
Old Nov 12, 2003 | 04:36 PM
internetautomar's Avatar
mod or sell?
Did someone say mandrel bends?
I got those
Old Nov 12, 2003 | 07:05 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
good god you seem to have it all. how bout heads or a motor (ve) ?
Old Nov 12, 2003 | 07:13 PM
mtcookson's Avatar
well... my luck wasn't meant to last. turns out there is hardly any room to made my "box" to let the exhaust flow through. so, i guess i'll have to make that manifold quicker than i thought.
Old Nov 12, 2003 | 07:22 PM
MrGone's Avatar
I got those
you do? well why the heck didnt you say anything before? Jeeze, I might have someone will buy them from you.
not telling me you have mandrels....
Old Nov 12, 2003 | 07:23 PM
mtcookson's Avatar
where are the pipes located on your page?
Old Nov 12, 2003 | 07:29 PM
subs1000w's Avatar
yea lets see the prices and for what size pipe
Old Nov 12, 2003 | 08:12 PM
mtcookson's Avatar
i may have another simple fix. just buy a right/rear manifold off of a 300ZX or 2nd gen Maxima and put it on the front. i would then need to do something about the crossover pipe but it would be a lot easier than making a manifold.
Old Nov 12, 2003 | 08:35 PM
mod or sell?
Not yet. But I can always look if demand warrants it
Old Nov 12, 2003 | 08:40 PM
mod or sell?
They're not, yet. It takes alot of time to put this page together and it keeps growing and growing and growing
I think I'm gonna have to split it up soon
BTW I have a thread going http://forums.maxima.org/showthread.php?t=261007 that I am sking for what People want on the page. So just tell me what you want and I'll toss it up there.
Old Nov 12, 2003 | 08:41 PM
mod or sell?
what size pipe you want?
Old Nov 12, 2003 | 11:34 PM
mtcookson's Avatar
Before I forget, I'd like to thank and give recognition to LittlePiggie for giving me the idea to check the manifold. I more than likely wouldn't have checked it if he didn't bring it up. Thanks man!
Old Nov 13, 2003 | 06:42 AM
DanNY's Avatar
Ad·min·is·tra·tor
did you not think to LOOK before you cover the plate?
Old Nov 13, 2003 | 08:29 AM
StinkyZ's Avatar
Just curious but how do you have the manifolds setup with the turbo? Got an pictures?
Old Nov 13, 2003 | 09:47 AM
subs1000w's Avatar
pics here
http://www.cardomain.com/id/mtcookson
Old Nov 13, 2003 | 10:11 AM
mtcookson's Avatar
actually, i did before but it never registered in my brain that they were seperate from each other. oh well, its a learning experience.
Old Nov 13, 2003 | 06:01 PM
YoU CaNt SeE mE
tell me about learning experiences...wel i know how to do timing now after i broke it !!!
Old Nov 13, 2003 | 09:04 PM
mtcookson's Avatar
here's my day in a nutshell
well... i didn't get to buy that rear manifold like i had planned. instead, my dad wanted to try fixing the one i had. we took it to my uncles shop and cut off the entire flange where the turbo bolts to. after that my dad took the cutting torch to it and cut off a bunch of metal so the cylinders could flow pretty freely to the crossover pipe. nissan makes some amazing cast iron. it welds and cuts very well. after that we took it to a guy to have a plate welded on. he did that and i headed home to put it all back together.
after about an hour i finally got everything back together and was ready to start it. i turned the key and it cranked a bit and vrroooom started right up. it sounded sooooo good. nice and smooth and idled very well. i revved it a bit and it revved so well. i ran it to my house to get some anti-freeze and filled it up.
i drove it around a bit with my dad and picked up my brother. i kept the rpm's down so it could warm up and since it was really the first time its actually got to run a lot. i went to the highway and got into second gear and hit the throttle and had some nice boost going into the engine. something didn't feel right and i slowed down. the engine died so i put it in 2nd and released the clutch to start it back up. the thing wouldn't rev very well at all and was running insanely rich.
i finally get it back home so my dad and i could take a look at it. i pop the hood and he looks under there and my dad says well this pipe came off. i was like suhweet!! intake pipe came off so i wasn't getting a good airflow signal.
i put it back on and tightened everything down real well. took it back out and got on the highway. started in first and nailed it.... it felt sooooo damn good. put it into second and it just kept on going. so, i can finally say "I HAVE BOOST!!!!"
it still needs to be tuned quite a bit because it doesn't quite feel like its running as good as it should. it has a tiny miss every once in a while but... i can't complain. i'll check the timing and take it to a dyno, if i can, to see what kind of a/f readings i have.
Old Nov 13, 2003 | 09:45 PM
Matt93SE's Avatar
STFU n00b!
Congrats! bout frikken time you got it up and running!!
I highly suggest putting a bead on the ends of the intake tubing so the pressure doesn't blow them off.
and be sure not to blow the engine up playing with it before you get it to the dyno!
Old Nov 13, 2003 | 10:08 PM
KLoWnPR109's Avatar
congrats on getting it running. Make sure to post the dyno numbers once you get it tuned
Old Nov 13, 2003 | 11:25 PM
mtcookson's Avatar
yeah, i definitely need to bead the end of the pipes. know of a good way to do this?
right now its running very rich so at the least i won't have any detonation. i'll start looking for some dyno places tomorrow so i might have some numbers by the weekend. i've driven it a bit more tonight and it seems like its running really good. i haven't noticed any problems yet at all and hopefully i wont get any but that's pushing my luck, lol.
Old Nov 14, 2003 | 02:08 AM
LittlePiggie's Avatar
niiiice man!! I'm glad to hear it's up!!
Old Nov 14, 2003 | 11:05 AM
mtcookson's Avatar
since i don't have a digital video camera i'll record some sound clips to give a taste until i can get a camera. (just incase you guys think i'm all talk )
Old Nov 14, 2003 | 01:37 PM
Matt93SE's Avatar
STFU n00b!
to bead the pipes... are they steel?
they make beading machines for this, but they're a couple hundred bucks.
you can also "modify" some vice grips by grinding down the grips on them to mash a bead into it..
another way is to weld a small bead of material all the way around the end. it's more difficult to get it straight and even, but it works too.
Old Nov 14, 2003 | 01:40 PM
mtcookson's Avatar
hmm... i might try welding around it. that should work for now.
the pipes are aluminized steel i believe. its whatever exhaust shops use.
Old Nov 14, 2003 | 01:55 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
great that is running!
if you are using regular clamps, try some T-bolt clamps instead. they seem to hold much better on bead-less pipes
Old Nov 14, 2003 | 01:57 PM
mtcookson's Avatar
yeah, i just have some regular ss clamps (at least that's what i call them). i probably have some t-bolt clamps laying around somewhere.
Old Nov 15, 2003 | 09:19 PM
StinkyZ's Avatar
Nice to hear you got it running. So its running with the bigger injectors and modified ecu? Cant wait to see what the dyno says. What kind of boost are you running?
Old Nov 16, 2003 | 12:57 AM
mtcookson's Avatar
yeah, i'm running the larger injectors with the modified ecu. its running extremely rich, though, and i even have the fuel pressure quite low... like 28 or so at idle. either it isn't quite tuned right or the injectors are actually bigger than i thought.
i'm only running around 7 psi... i think. i've not really had a chance to tell what its hitting since it accellerates too dang fast. the spring on the wastegate is for 7 psi so it should be at that.
edit: forgot to add a few things i did tonight.
fixed my temp gauge i believe. somehow it wasn't adjusted correctly. i'm pretty sure the needle is supposed to point straight down when adjusting it, but could someone comfirm this for me? i've not messed with my needles in so long that i can't remember where it is supposed to sit when the stopper pin is out.
i also got rid of my stupid clock that sits there and flickers the whole time. i put my boost gauge there so now i have a place for a 2 1/16 guage in the future to go along with the 3 that i'll be able to put in the pod.
i'll try getting some pictures up sometime and get that recording i said i would get.
Old Nov 16, 2003 | 07:00 PM
|Bijan|'s Avatar
UCF Lexus
hell yeah!
Old Nov 16, 2003 | 07:35 PM
AscendantMax's Avatar
congrats man!
i'm curious on how much torque you're putting down
