Stearing Problem
Old Nov 15, 2003 | 07:05 AM
landjet32's Avatar
Stearing Problem
Okay, I replaced my stearing gear because my stearing wheel wouldnt center. Before I replaced the gear, when I would go around right turns and then go straight, my stearing wheel would stay to the right. When I would go around left turns and then go straight my stearing wheel would stay to the left. Anyway, after replacing the gear, it now centers, however, I think I had more than one problem going on. Now when I accelerate, as the car shifts through the gears (automatic) it pulls to the right. This is more than just an allignment problem because the stearing wheel will turn if i dont hold it center and after I get up to speed, it stops pulling and drives straight and smooth. Also, If i accelerate hard I hear a poping noise comming from under the car as it pulls to the right. Any ideas? Im leaning toward mounts, gonna check them out first. If I should look elsewhere please speak up.
Old Nov 15, 2003 | 07:49 AM
CandiMan's Avatar
Say Candyman 5 times
Control arm bushings
As I started reading you post, first thing that came to mind was an alignment problem. Because your caster predicts how easy it is to steer and when the sterring wheel should return to center. Then you stated the replacement steering box corrected the centering problem but now it pulls as the trans is upshifting thru the gears and if you eccelerate hard you hear a poping noise which leads me to believe your control arm bushings are worn. They could be so worn that's it's effecting your caster setting.
Old Nov 15, 2003 | 09:35 PM
james93gxe's Avatar
I would check tour motor mounts. I went to get an alignment because my car was pulling to one side and they noticed my front motor mount was in pretty bad shape. Among the causes of the pulling problem, they said that the broken mount was causing something called torque steer. Not sure exactly how that works but its could be something to consider.
Old Nov 15, 2003 | 09:42 PM
internetautomar's Avatar
mod or sell?
My car had that problem too when I got it. Replaced the bushings/arms and much better now. Just need an alignment
Old Nov 15, 2003 | 09:50 PM
mod or sell?
Oh yeah, Matt and I sell the control arms
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
