Question on changing front brake pads
Old Dec 4, 2003 | 02:46 PM
Saad Zaidi's Avatar
My Nissan's maxima (1992 SE) from brake pads are almost out (15% left)
and I was planning on installing a new set of brake pads.
Brake depot is charging me $130 ( including the parts ) - I was thinking on saving some bucks and doing it myself.
Could someone kindly post instructions on how to do this and what tools may be required. I inquired at Auto Zone and was told that good quality brake pads would cost me around $40.
Please advise.
Thanks,
Saad
Old Dec 4, 2003 | 02:58 PM
Jeff92se's Avatar
I'm needing a caw
http://www.cybrrpartspro.com/Chilton...961m/8961.HTML
Read it, know it, make love it, marry it etc.... Enjoy!
Old Dec 4, 2003 | 03:00 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
front pads are easy to change, youll need basic hand tools, rachet set and most likely a C-clamp to compress the caliper.
1- pull ebrake then put something behind the wheels, so it dosent roll ( i use large rubber wheel chocks) then jack the car p and support it with jack stands. NEVER USE THE JACK TO HOLD UP THE CAR ! my buddy did this and the car fell on him and broke his ribcage.
2) remove tire with lug wrench
3) on the back side of the caliper you will need to remove two bolts holding it on. then pry it off the rotor. ALSO remember to inspect rotors for warping and take a quick look at the brake lines for cracks. now take the old pads out of the caliper. use the c-clamp and recompress the caliper slowly till the piston is back in the caliper. insert new pads into the caliper and place back on rotor insert caliper bolts and tighten to factory torque specs with your torque wrench. (if you dont have one use a socket and make it tight but dont CRANK IT DOWN. replace tire and do the same on the other side. after the other side is done then check fluid level in brake resevoir and then with the car off push the brake petal to the floor a few times the petal should tighten up and you shouldnt be able to me it much now start car and test it SLOWLY FIRST !!! if you have disc in the rear then the instructions are the same. if you have drum then thats a different story let us know if you have drum rears....
Old Dec 5, 2003 | 05:56 AM
internetautomar's Avatar
mod or sell?
Brake jobs are "easy" Just try to be sure to have everything ready before you start. Saves Lotsa trips to the parts store
I sell everything you need for the brake job
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
