fuse cover, antena, and door lock help in stl
Old Dec 4, 2003 | 04:15 PM
killthetorment's Avatar
alright, i have had my 94 for a couple of months now, and there are a couple of things that i need to do to it to make it a better car. first of the fuse cover on the drivers side is very lose, it likes to fall off when it feels like which is annoying while i am driving, i dont know of where i could get a new one of these or some quick fix.
secondly my antena is bent, it was like this when i bought it. so right now it does not retract all the way, it gets stuck about half way. and it also gets crappy reception, no this could also be the cd player that is in the car i dont really know. but what would i have to do that would fix this?
lastly, the rear drivers side door is odd, to get it open the outside handle has to be used and the inner pull up lock needs to be lifted at the same time. why the hell is that? what needs to be done to fix that?
give me your thoughts guys, cause these problems are drivin me batty
Old Dec 4, 2003 | 04:34 PM
subs1000w's Avatar
you could go to a junk yard to get a new fuse cover and antena
i would say take the door panel off and inspect the lock linkage somthing could be bent or broken if you need any help let me no i live in st louis
Old Dec 5, 2003 | 07:00 PM
BML94GXE's Avatar
Maxima Withdrawl is real
well i have never done this myself, but would heating up the antenna with a torch (lil propane ones at lowes) and then bend it back work? just an idea I had for fixing my friends, but have not gotten there, as for the fuse cover you could always put a lil electrical tape around the prong thingies on the bottom to stop some movement. yeah, just a thought, but the tape kinda a temp thing.
Old Dec 5, 2003 | 10:30 PM
closer look
i looked closer at the fuse cover and i found that the bottom prongs hold fine but it is the top that is really lose. it is almost like there is nothing for it to catch on all the time.
as for heating the antena, wouldnt it have to be pretty hot to bend it back and then run the risk of messing it up more?
thanks for the ideas though
Old Dec 6, 2003 | 06:20 PM
internetautomar's Avatar
mod or sell?
Doesn't have to get that hot.
just warm enough to add a little pliability so that it stays the way you bend it
Old Dec 6, 2003 | 09:56 PM
DMad8724's Avatar
ummm 1
go to a junkyard and get a new cover
ummm 2
bend your antenna back
and ummm 3
check your child safety lock in the door jam, or get a new door!
Old Dec 6, 2003 | 09:59 PM
how do i check the child safety lock on the door?
Old Dec 6, 2003 | 10:31 PM
mod or sell?
in the door jam itself is a little lever marked child safety lock.
Or if you have an owners manual read it there.
johnaschon
Sep 14, 2015 04:29 PM
jwright36
Sep 8, 2015 11:45 AM
Hailstatejig
Sep 2, 2015 06:52 AM
