where is this hose connected to???
Could somebody help me take a look? I recently changed the injector and I suddenly found this hose this morning? Searched everythere but didn't find
where it should go...
Many many thanks.
BTW, is the searching function working properly?
Many many thanks.
to me it looks like a run off line or moisture vent. but from the angle of the picture....i can't seem to recall from where.
i'm pretty sure your safe....but better let some other ppl here check this out to be sure what it is. someone will know for sure.
Originally Posted by -shock211-
no....you need to run a hose from there to the front of your car where the fake intercooler airbox is. then you'll get 11hp, 12hp if you have a green filter, 13hp if you add the sticker too.
ok, now we have done killed da dead cat 3 times...
Originally Posted by e_is_chillin
Does the car start? If so just tie wrap to something. "Tie wraps, 1,000,000 uses... now 1.000,001"
Hey I was j/k but if it starts than you are in better shape than if it didn't. Some times a vacumm hose might pevent the car from starting. Take your time and hunt it down, piece by piece. You'll find it. It has to get connected to either the motor/intake or to another hose. Have someonee helps you. Sometimes four eyes are better than two.
HerpDerp1919
Sep 29, 2015 02:02 PM
catalinvint
Sep 16, 2015 07:48 PM
