Flushing the Radiator
Old Dec 28, 2003 | 10:54 AM
xdannyx25's Avatar
i have the preston kit thing, but the hose i believe its refering to cut is to big for the adapter. am i looking at the wrong hose, believe its the upper radiator hose?
if so is there a kit or something to flush the radiator?
Old Dec 28, 2003 | 11:14 AM
internetautomar's Avatar
mod or sell?
Try the heater hose
Old Dec 28, 2003 | 11:15 AM
xdannyx25's Avatar
yeah just read it and it says the heater hose, there are 3 hoses about half inch wide at the bottom of the radiator driver side. which should be good. but which one do i cut. am i looking at the right hoses yet?
Old Dec 28, 2003 | 11:26 AM
Mike S.'s Avatar
Well there are 2 heater core hoses at the top of the engine. They come out of the back and go into the firewall (sending coolant to the heater core). I'm not sure if it would matter where the flush point begins since it will evenutally make it back to the starting point.
BTW: how much was the flush kit?
Mike S.
Old Dec 28, 2003 | 04:04 PM
Paul89SE's Avatar
Yeah, i bought the kit too. It's worthless there was only 1 0f 5 things that you could even use. In my opinion you could get the same effect by sticking the hose in the radiator. Heater hose is definitely your best bet.
Old Dec 28, 2003 | 06:18 PM
mod or sell?
Hehehehe
I told him that on IM earlier
Old Dec 28, 2003 | 11:42 PM
xdannyx25's Avatar
yeap, told me that. i tried that and did it for awhile till the water came out clean. but when i added coolant.....i squeezed the upper radiator hose a few and bam the inside felt like gram crackers, after the squeeze the cracker feel went away. aww crap i clogged it again or something. its still over heating ima try again tommorrow and use a coolant specified to take our residue and deposits....
-no leaks
-coolants good
-cap is new
-fans kick in, both of them
only thing i can think of is the thermostat cause the water pump is good when i was flushing it with the car on, alot more water came out. it takes about 5-10 miles for it to over heat starting on a cold start.
Old Dec 29, 2003 | 05:07 AM
mod or sell?
Replace the upper hose!
if it has any kind of buildup in it. It has been on too long.
Change the bottom one too while you're at it.
it's better than risking one popping while you're drivcing.
One of them may also be collapsing and causing the overheating (just thought about that me )
Old Dec 29, 2003 | 11:26 PM
xdannyx25's Avatar
one big f*ck up. after cleaning every hose, having the flushed water come crystal clean. we drive it for a while, now its heating up see some smoke pull the hood up and see a hair line leak on plastic top of the radiator. we put some silicone = dont work it stretches. took that off, guy at autozone said use this liquid thing should solve it. he said he tried it on his had good leaks and worked good. ok we put that let it run on idle and still over heated. put the rest of the bottle and added coolant then went home. still overheating. maybe with luck it starts to fill the leak till i can get good radiator. but dam im ****ed and tired.
anyone know the estiment of a new/use radiator so i can be aware of.
Old Dec 30, 2003 | 08:59 AM
Paul89SE's Avatar
$95+ shipping from internetautomar. He also has a couple of better ones for a little bit more.
Old Dec 30, 2003 | 09:51 AM
87MustangGT's Avatar
Try AutoZone too - I just got a rad for my Tempo for like $75 or something...
Old Dec 30, 2003 | 10:04 AM
johnnyo319's Avatar
Is there a writeup on how to flush the coolant system? I did it a year ago and i don't know if i did it right.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
jchronis2552
Sep 23, 2015 04:57 PM
RWCreative
Sep 21, 2015 11:01 AM
