Help locating headlight sensor
Old Jan 2, 2004 | 02:36 PM
Phnx34's Avatar
Hi,
Does anybody know the location of the sensor/relay that controls the illumination of the console and tail lights during nighttime driving? Seems that my car has stopped activating these lights when the headlights are turned on. The effect is a pitch black console and the appearance that I left my lights off to motorists behind me. Any help is appreciated as driving like this seems somewhat unsafe.
Thanks,
Paul
Old Jan 2, 2004 | 04:20 PM
90SEBlack's Avatar
Chances are its a short in your taillight any rust holes in the trunk area or did it rain within a week of this hapening , pop open ur taillight compartments and look for fried wires or bulbs i would also check the fuses all of them that have to do with lights (turn signal, illumation, speedo) i think that what they are i know there are a few that blew when i had the same problem along with a leak from installing my new spoiler. Goodluck
Old Jan 2, 2004 | 09:28 PM
Phnx34's Avatar
Thanks. The fuses all check out, but I guess that's expected since all tail lights remain operational (at all times) when used for their individual functions (brake, reverse, turn signal). They just refuse to light up for normal night time driving. The best description I can give is that people behind me wouldn't see me until I hit the brakes. As suggested, I'll check back there for any obvious wire damage and anything else anybody can think of before I bring it in.
Thanks again,
---Paul
Old Jan 2, 2004 | 11:14 PM
ghostmax's Avatar
Pull the fuse for STOP Lamp and replace with new even if the fuse checks out. The problem is a fuse. Do you have your door lights too?
Old Jan 3, 2004 | 05:44 AM
Phnx34's Avatar
No luck replacing fuses. But, I'll dust off the old multimeter to test for continuity along that circuit.
---Paul
Old Jan 3, 2004 | 06:24 AM
nubiannupe's Avatar
OG Maxima.org Member
---Paul
Paul, I had a similar problem not too long ago. Turned out to be corroded pins in the headlight switch, if you can believe THAT.
Old Jan 3, 2004 | 06:00 PM
internetautomar's Avatar
mod or sell?
I concur with nupe.
It sounds like a headlight switch.
Start with your multimeter there first
Old Jan 5, 2004 | 12:30 AM
Phnx34's Avatar
I just checked and the door lights do come on. As suggested, I'll check out the headlight switch. The headlights are working fine so is there a separate switch in there that I should be looking for?
It's been pouring this weekend so I haven't had a chance to check it out. I'll also look for any corroded wires in the rear while I'm at it. This is annoying because I know it's going to be something really simple.
Thanks again guys for all the help!
---Paul
Old Jan 5, 2004 | 05:36 AM
nubiannupe's Avatar
---Paul
It usually is, Paul. I know I went crazy trying to figure out what the problem with my lights was - that was until I read a post here about 3-4 months ago about someone checking/swapping out the headlight switch.
And it's a combination switch, so it's multi-function. My headlights were working as well - just nothing else.
So, I went on a hunch, pulled the darn thing, and sure enough the contacts were a little 'green around the gills'. Took one of my pin files from my model building (an emory board works on it too, IIRC), cleaned it up, put it together, and all was well.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
95Maxi
Sep 2, 2015 08:49 PM
maximusrising
Sep 2, 2015 09:55 AM
