Crusing Speed II with PICS
Old Jan 6, 2004 | 01:04 PM
90SEBlack's Avatar
Ok so i opened up my old guage cluster and found that conversion that i was talkin about and it makes no sence to me, I know that my engine is tuned as best as its gunna get and im runnin 2,000 - 2,100 RPMs at 60mph and the speedo conversion says 60mph = 1024RPM thats offly low and dunno how i could get that low if i tryed , Anyway is this just some sort of electronic conversion or something??What do u guys think??? You can see the conversion on the bottom right of the speedo kinda blurry but as clear as i could get it. Says 60mph=1024RPM
Old Jan 6, 2004 | 01:44 PM
mtcookson's Avatar
my gauges say the same thing but i have no clue what it means.
if you are wanting to make sure your speedo is reading the correct speed get a stop watch and drive 1 mile at 60 mph. after 60 seconds you should go exactly 1 mile.
Old Jan 6, 2004 | 02:48 PM
Bill Brasky's Avatar
Seperated at Birth?
it has nothing to do with cruising speed. it's jsut Nissan's way of calibration.
Old Jan 6, 2004 | 03:18 PM
90SEBlack's Avatar
duh but if your crusing at 60mph then ur RPMs should read 1024 if that calibration is correct, are u understanding what is being stated.
Old Jan 6, 2004 | 03:21 PM
Spipedong90's Avatar
what it means, is that the gear in the transmission that sends the signal to the gauge turns 1024 RPM at 60MPH, it has NOTHING to do with your engine.
If you had the engine off and rolled the car down a hill at 60, the transmission sender would still turn at 1024 RPM, indicating 60 on the speedo if properly calibrated..
Old Jan 6, 2004 | 03:25 PM
90SEBlack's Avatar
Thank you that explains it. I understand now, never thought of that and ur right cuz when i towed the one junker and had the ignition on for the lights the speedo registered the speed.
Old Jan 7, 2004 | 11:45 AM
shoult's Avatar
Going only one mile will introduce human error. You're never quite as close to perfectly starting and stopping the timer as you think. A better way is to drive 5 or more miles. This lets you spread the same amount of error over more miles.
I've calibrated several cars this way and it was the way State Trooper cars used to be calibrated before they were done electronically.
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
JonBlz
Oct 5, 2015 06:02 PM
Marc2theMax
Sep 28, 2015 08:13 AM
