People with lightweight flywheels
Old Jan 6, 2004 | 05:08 PM
MethMax's Avatar
Has anyone with a lightweight flywheel had an Idleing problems when it was cold out? It runs fine after it warms up.
Old Jan 6, 2004 | 05:15 PM
D-sta's Avatar
Never, I have an ACT clutch with an AASCO flywheel.
Old Jan 6, 2004 | 05:17 PM
StRacer718's Avatar
I have the UDP and when I first start the car it feels like it wants to cut off. Then after about two or three minutes it purrs like a kitten.
Old Jan 6, 2004 | 06:26 PM
Matt93SE's Avatar
STFU n00b!
nope, and I've got UDP and flywheel.. can't get much lighter.
Old Jan 6, 2004 | 06:36 PM
mtcookson's Avatar
you can get a lightened clutch as well. if they make them for our cars.
Old Jan 6, 2004 | 06:40 PM
Cliff Clavin's Avatar
Way out West
I think your idea of cold (in Houston) and MethMax's idea of cold in St. Paul, Minnesota are probably a little different! (j/k Matt)
MrGone has a lightened flywheel and he has an opinion about everything. Ask him.
Old Jan 6, 2004 | 06:42 PM
N34JZ's Avatar
Needs non-Maxima Friends
same here /
Old Jan 6, 2004 | 10:08 PM
MrGone's Avatar
I have a Fidanza, No problems what so ever (caused by the Fidanza that is).
I had a vacuum line come off the back of the manifold about two weeks ago, that made my idle crappy, but it wasn't because of the fidanza.
Old Jan 7, 2004 | 03:56 PM
MethMax's Avatar
Yeah its been butt cold up here for about a week now, and that is probably the problem. When it first happened I was was like now whats wrong.
Old Jan 7, 2004 | 04:03 PM
MrGone's Avatar
also my problem was the car idled like crap when it was warm, not cold. (that was the vacuum hose)
Another experience with mine:
I bought my car with a bad tranny, so after I replaced everything I just working on the car, making everything was good, and the VTC's started knocking, so I grounded them. Since I hadn't even taken my car out on the street yet, I didnt know what was the problem, tried O2, nothing, tried some other things, etc, nothing. Turns out it was because the VTC's were grounded, The computer just has to get used to it I guess. Now I have them on a switch, when I flip the switch sometimes the idle can get rough, but not really as drastic as before (bouncing inbetween 500 and 1000rpms back and forth for maybe 5 seconds or more, plus viberating the whole car).
Since you dont have VTC's, that doesn't help you very much. Maybe check the Idle Air Control?
Old Jan 8, 2004 | 09:35 AM
Lordrandall's Avatar
No problems in CA with my Fidanza/ACT, but it doesn't get that cold here.
Old Jan 9, 2004 | 03:46 PM
StRacer718's Avatar
For the past three days here in NY its been hovering between 25 and 10 degrees. I have to run my car for 5mins just for the temp. guage to move off the needle.
Old Jan 9, 2004 | 04:12 PM
bonzelite's Avatar
no idling problem. but when it is cold, there is slight slippage. this goes away when the parts warm up. i have valeo clutch and fidanza flywheel.
Old Jan 9, 2004 | 04:14 PM
bonzelite's Avatar
oh yes. matt. slam dunk this to bed finally: is the crank pulley on the VG really the harmonic balancer? that is, does the UDP on that engine f&*cK it up?
now lets get back on topic... (heh)
Old Jan 12, 2004 | 04:20 AM
MrGone's Avatar
figure it out?
Chad- yes and no. Normally I think of harmonic balancers as parts that if you take off, engine go buh bye! when you try to run it again.
(example: ford SB v8's aren't internally balanced, so they need a harmonic balancer on the front of the crank (mine just happens to be built onto the pulley). If I modify it, the engine becomes unbalanced and I can snap the crank. blah blah blah.
(if your going off that whole bimmer thing, dont worry about it).
Old Jan 12, 2004 | 03:16 PM
StRacer718's Avatar
Does the flywheel really have a major affect on the way your car idles?
Old Jan 20, 2004 | 07:05 PM
jkmay01's Avatar
Lil 8
that has been my reluctancy in changing mine over is the uncertainly in the idle and whether or not the crank pulley will really cause more damage than good? When i do a mod i dont want to wait 15 minutes for the car to act right due to the mod.. Got me!!!
Old Jan 25, 2004 | 12:55 PM
bonzelite's Avatar
jkmay01, don't worry about it.
shawn, thanks.
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
BobTX10
Oct 7, 2015 08:43 AM
REDinLV
Sep 28, 2015 12:31 AM
