92 SE injectors
Old Jan 8, 2004 | 11:54 PM
mrgoogs's Avatar
92 SE injectors
Hey.
I have replaced my injectors twice now and still having rough running and intermitent stalling. I bought used ones recenlty and 4 read 11.1 ohms while one reads 11.7, so I'm trying to figure out if this is good or bad.Can i install the 11.1 and 11.7 or are there 12.0 ohms injectors or something-which is better????
mrgoogs.
Old Jan 8, 2004 | 11:55 PM
mtcookson's Avatar
i believe as long as they are between 10 and 14 ohms they are fine. can anyone else backup my statement?
i do know that the injectors on my engine read about 12.5 and they work just fine.
Old Jan 8, 2004 | 11:58 PM
mrgoogs's Avatar
Does 11.1 or 11.7mean that they are going bad or what, I' guessing since yours are 12.5??!!
mrgoogs
Old Jan 9, 2004 | 12:08 AM
MrGone's Avatar
na
mine were between 11.6 and 11.8 IIRC +/- .1
Old Jan 9, 2004 | 12:13 AM
mtcookson's Avatar
when they go bad they are usually way off. not sure if they go high or low but they are way out of the range they should be in which i'm pretty sure is 10-14 ohms.
my injectors are probably at 12.5 ohms because they aren't the stock ones. they came on the turbo engine i have.
Old Jan 9, 2004 | 12:46 AM
mrgoogs's Avatar
ThanKs guys!!
Old Jan 9, 2004 | 04:10 PM
eric93SE's Avatar
Originally Posted by mrgoogs
Hey.
mrgoogs.
Your injectors are well withing spec.
You might want to clean your IACV (idle air control valve), If the search function is working you can find a couple old threads where I described an easy way to clean it out. Or you can remove the IACV and do a more thorough cleaning (so long as your are very carful, b/c there is a small spring that can pop out on you, its happend to others).
If you do plan on going the route of removing the IACV, then make sure you first buy the new gasket (the dealership may have to order it, none of the dealers by me carry it).
Old Jan 10, 2004 | 08:51 PM
internetautomar's Avatar
mod or sell?
just as a side note.
even if injectors are within ohm range does NOT mean they are functioning correctly.
Old Jan 11, 2004 | 03:24 PM
eric93SE's Avatar
Hey.
mrgoogs.
You can also do a fuel pressure test, to verify that the fuel press regulator isn't bad.
Another thing to check is the transistor pack, that fires the injectors.
Old Jan 11, 2004 | 04:32 PM
mtcookson's Avatar
transistor pack? something on the ve? i thought the wires went directly from the ecu to the injectors.
Old Jan 12, 2004 | 12:58 AM
MrGone's Avatar
I thought the transistor pack was for the Coils.
Old Jan 12, 2004 | 01:23 AM
mtcookson's Avatar
yeah, i was thinking that too.
Old Jan 12, 2004 | 03:06 AM
nubiannupe's Avatar
OG Maxima.org Member
Sounds like a VG thang...
Old Jan 12, 2004 | 11:59 AM
eric93SE's Avatar
Yes the transistor pack is for the coils.. He's describing, "rough running and stalling" so its another suggestion. It can easily be checked out with the use of the FSM.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
