Very Very Cold -7 F
Old Jan 10, 2004 | 06:09 PM
90SEBlack's Avatar
Very Very Cold -7 F
I got up this morning and went to start the car in -7 maybe colder weather and the starter just grinded didnt crank the motor i tried it again and the same thing happened then i tried a third time and it started grinded but began to crank and started right up idlded just fine and drove just fine any ideas why it may have done this, Just a note it has new 10w-30 in the pan as of 500 miles ago.
Old Jan 10, 2004 | 06:12 PM
davebond007's Avatar
Bad starter. Time for a new one.
Old Jan 10, 2004 | 06:33 PM
nubiannupe's Avatar
OG Maxima.org Member
on this one...
Old Jan 10, 2004 | 06:38 PM
MrGone's Avatar
hahahahahah
note to self. make dave go exchange my starter
Old Jan 11, 2004 | 09:00 AM
90SEBlack's Avatar
Well this problem persisted for 3 days all below 2 Degree F today about 28 had no problems starting it today and late yesterday first click started right up, assuming that it is my starter going bad do u think that this problem will only persist if the temp is down below 5 or so.
Old Jan 11, 2004 | 12:19 PM
drstillpatient's Avatar
nissan recommends 5W-30 oil for cold temperatures...helps in cold starts.
Old Jan 11, 2004 | 12:23 PM
btw...i had 10W-30 until 2 weeks ago and i used to feel my engine didnt wanna turn in cold morning start-ups, and once it turned, it sounded like it turned realy slow...i changed to 5W-30 and its perfect every morning
Old Jan 11, 2004 | 02:05 PM
Ninty-two-se's Avatar
I had a similar problem in the cold weather (-12 F) here, my starter would just spin with out engaging the flywheel... I figured it was a bad starter and pulled it into the garage to take the starter off and exchange it for the one on my parts car... after about an hour sitting in the warm garage it would start up everytime... so try puting the car some place warm and see if it starts better... still could be a bad starter.. how could you tell if the problem only happens in subzero temps?
Old Jan 11, 2004 | 02:17 PM
rcy's Avatar
rcy
Someone else posted this... www.motorvate.ca in response to my starter doing the same thing, only when cold. It's for a fourth gen, but I imagine it would work on our starters as well. Something to do with the grease getting old and dry...you really notice it in the cold.
Just as an aside, I installed an lower rad hose in line block heater ($30 at Canadian Tire) two nights ago, and I haven't had a problem with the starter since using the block heater. Good for overnight in the driveway, but I'd need a really long extension cord to use it at work.
Old Jan 11, 2004 | 05:44 PM
StRacer718's Avatar
Cars behave abnormally in the cold, especially as cold as it has been the past four days here in NY. I envy the people who live in areas that never see below 50 degrees!
Old Jan 11, 2004 | 05:47 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
damn weather
Old Jan 12, 2004 | 08:27 AM
rcy's Avatar
rcy
Yes, but they'll never know the joy of an empty parking lot, fresh snow, and a working parking brake.
Old Jan 12, 2004 | 11:52 AM
94M@X's Avatar
Oh YEAAAAA!!!
Old Jan 12, 2004 | 03:10 PM
StRacer718's Avatar
The only thing I appreciate about winter driving is the cold air increases the torque output. My car just feels faster now than it does in the summer.
Old Jan 12, 2004 | 04:00 PM
anaximander's Avatar
A semi-weak battery may also cause starting problems when cold.
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
yamehoo
Sep 24, 2015 10:21 AM
msellas
Sep 23, 2015 09:16 PM
