need edvice please!!
i just got my wife a 1990 gxe and i went to the dealer to find the code for the
key pad but they want this life and the other ,any body knows if there is like a standar code or something any help will be appreciate thanx
its very hard to see, it took me three posts and three trips out to the car to find it, its a seven didgit code on the sticker. theres a small chance that it was removed by the dealer and youll be screwed. i still havent figured out how to override it
There's two sets of numbers for the keyless entry system. The first is the fixed number, the second is the code number.
Here's how to reset the code number using the fixed number.
1. Press the start/clear button.
2. Enter the 7-digit FIXED NUMBER. A beep will sound for 6 seconds.
3. Enter a 4- to 7-digit personal CODE NUMBER while the beep is sounding.
4. After the personal CODE NUMBER is entered, the beep will sound at short intervals. This indicates successful entry of the personal CODE NUMBER.
If wrong numbers are entered, the beep will not sound. Press start/clear button, then enter a correct personal CODE NUMBER.
The following numbers cannot be entered as CODE NUMBER;
Any number where all digits are on the same button. EXAMPLE: 1-2-1-2, 3-3-4-4
Any number requiring sequential operation of the buttons. EXAMPLE: 1-3-5-7 or 7-5-3-1
Any number with 3 of fewer digits.
Any number with eight or more digitrs. Continuously pushing random buttons will cause the system to stop functioning for 6 to 30 seconds.
Once you've set the personal CODE NUMBER to what you like, hit start/clear then enter the number to test it. Press the window or the trunk buttons immediately after if you want to open the window or trunk.
Before leaving the vehicle be sure to press the lock button.
Ahh the power of search.............
And yes it's by the glove box.
[QUOTE=Nozama]There's two sets of numbers for the keyless entry system. The first is the fixed number, the second is the code number.
ok i found the #'s and i put them in but nothing happend after i put the #'s in the key pad stop beepeeing ,did i miss something
