Ve Dyno Sheet Request
Old Jan 20, 2004 | 05:29 PM
MaDMaX024's Avatar
i'm up to no-good as usual, so i need some dyno sheets of VEs, i need both auto and 5speed, preferably simliarly modded but i'll take what i can get.
thanks guys.
Old Jan 20, 2004 | 05:36 PM
Jeff92se's Avatar
I'm needing a caw
Why do you need them?
Here's mine.
http://community.webshots.com/album/85315646YziGlN
Usual stuff. Y/I/JWT ecu/ks resistor. I've added the udp since then.
Old Jan 20, 2004 | 11:00 PM
MaDMaX024's Avatar
Here's mine.
thanks jeff...are you 5spd or auto?
as far as why i need them, its a need to know basis thing
if i need someones assistance, i'll ask that specific person..its a big IF project, so i'm not going to let anything out yet.
Old Jan 21, 2004 | 12:05 AM
davebond007's Avatar
Bad KS. Probably a bad O2 as well.
Old Jan 21, 2004 | 02:03 AM
Shawn, I think this one is yours...
Since you haven't had time to tune all 6 MSD Ignitions yet, I'll just post pictures of the trial run for you.
Old Jan 21, 2004 | 04:35 AM
Pervis Anathema's Avatar
Here's mine.
You make more torque at the wheels than I do at the crank...
Old Jan 21, 2004 | 06:56 AM
internetautomar's Avatar
mod or sell?
another vic of VGitis
Old Jan 21, 2004 | 11:13 AM
Jeff92se's Avatar
I'm needing a caw
Would someone stop using "donkey" as references. Not only is that copying someone else, it irritating as hell.
Old Jan 21, 2004 | 02:50 PM
MrGone's Avatar
now on read everything I say (that's technical) twice. You dont need 6 boxes if you set it up in a waste spark configuration.
Old Jan 21, 2004 | 04:24 PM
Matt93SE's Avatar
STFU n00b!
93SE 5 spd, ~160k miles. only mod is advanced timing at that point.
Old Jan 21, 2004 | 05:49 PM
subs1000w's Avatar
is it just me or does jeffs dyno seem low i mean matt and davebond both put down 165 with basicly no mods and jeff put down only 10 more and he has the BIG 3 major modds done i would think he should have seen at least 180-190whp
any opinion on this jeff or was your car not running completely right
Old Jan 21, 2004 | 06:21 PM
MaDMaX024's Avatar
is it me or do none of you auto VE guys dyno?
Old Jan 21, 2004 | 06:52 PM
MrGone's Avatar
subs- matt put down easily another 10 torque and I dont know what kind of weather that was in, but when Jeff/Dave dyno'd it was a rather cool, wet day.
Jeff doesn't have the CAI portion installed, and also Matt and Jeff do not have stock wheels installed. (well Matt might have at that point, but I dont think he did).
If I was dave, I'd be wondering where that extra 10lbs/ft went. I know I sure am.
Old Jan 21, 2004 | 07:51 PM
Matt93SE's Avatar
STFU n00b!
I had my 16" Enkeis on. weigh almost identical to the factory wheels/tires.
that might be part of Jethro's descrepancy, as he's running some huuuge Rustang rims on his..
the day I dyno'd mine, it was about 45-50 outside, but about 65 in the shop. those are uncorrected numbers if I remember correctly.
Old Jan 21, 2004 | 09:33 PM
The temperature outside shouldn't matter too much (they turn a fan on to provide the radiator with about 45mph of wind), it'd be the atmospheric pressure that I'd be worried more about.
Jethro's car also has the performance mods that dictate that type of power that he got (especially the torque). The Ypipe, ECU and JWT intake (giant cone w/ venturi), and KS resistor fix (sure helped my car, notice the heatsoak on the dyno?) are all performance mods. No body kit, flashy wheels, giant sound system to slow Mister Benihana ($20!) down.
I'm not wondering about the lost power. Compared to Matt's dyno, it's power gained (I :heart: Seattle's weather). Plus, I have a bad KS that retarded my timing quite a bit in that dyno. I almost want to dyno again now.
Old Jan 21, 2004 | 11:33 PM
Jeff92se's Avatar
I'm needing a caw
I think the reason why my HP is not that great is because I have a stock sized cat back. That's my only guess. I dyno'd somewhere near the same 175.x hp before on my crap motor but I had a Cattman Y, RT cat 2.25-ish cat back and y2k muffler. But I know my torque was nowhere near 185. Maybe the small pipe helps the torque too. I plan on switching exhaust systems for grins anyway. Maybe I'll dyno again since I have the UDP. Would like to finally get the Fidanza and ACT in also.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
umnitza
Sep 1, 2015 01:03 PM
jholley
Aug 30, 2015 06:39 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
