Injectors
Old Jan 23, 2004 | 08:40 AM
DopeAZmaxima's Avatar
Injectors
does anyone know where i can get good injectors for cheap? I tryed to search for a thread about this but it wont let me search?
Old Jan 23, 2004 | 08:53 AM
mark1957's Avatar
I have a complete fuel rail with all 6 injectors from a '94 GXE.Let me know if interested.
Old Jan 23, 2004 | 09:18 AM
im not sure if it would fit on my car because i have a 1990 SOHC
Old Jan 23, 2004 | 09:30 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
the GXE's have SOHC motors
Old Jan 23, 2004 | 09:38 AM
do you think that the fuel rail from a 1994 would fit on a 1990?
Old Jan 23, 2004 | 09:44 AM
-shock211-'s Avatar
yes......it would fit.
Old Jan 23, 2004 | 10:30 AM
internetautomar's Avatar
mod or sell?
yes BUT the connectors are different
Old Jan 23, 2004 | 11:02 AM
-shock211-'s Avatar
good point...
if the injector colours are the same on the 94 as yours, then you are clear to swap em' if not you can always switch the plugs but that might be a little to involved for a job like this. you don't want to throw off the resistance and power that the injector needs by making a half a$$ connection...
automart,
you so SMART!!!
Old Jan 23, 2004 | 11:16 AM
mark1957's Avatar
My connectors are pink with the yellow dot. If you need ones with the blue dot there is set on eBay now, just search Nissan injectors.The ad says Nissan OEM fuel injectors.
Old Jan 23, 2004 | 11:59 AM
mark1957's Avatar
I also just verified that #5 injector ohms out as a bad one.Other 5 ohm out fine [btwn 11 and 12 ohms.
Old Jan 23, 2004 | 02:13 PM
mod or sell?
the 89-91 max uses a pink with either black or blue dot injector.
the 92- ?? uses a red injector.
Old Jan 23, 2004 | 07:17 PM
yea my injectors are pink with a blue dot
Old Jan 24, 2004 | 01:10 PM
Phnx34's Avatar
Remanufactured injectors
Injector cleaning
Old Jan 24, 2004 | 07:07 PM
mod or sell?
Then don't get a reman injector.
they have in my experience far to high of a defect rate.
Get a brand new bosch (O.E.) for about $100 and save yourself the headaches
Old Jan 24, 2004 | 07:15 PM
89badmaxse's Avatar
i have an extra fuel rail with injectors off of an 89 max it was an se but i donthitn it makes a differencesince 89-91 se's and gxe's have the same engines let me know if it souinds good to you
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
