More Climate Control Problmes
Old Jan 30, 2004 | 09:10 AM
jtriplett's Avatar
I have an 89 SE. The guy I bought it from had replaced the climate control panel, and now the dash vents blow cold air when any other vents are
selected. I keep the dash vents tunred off, but they still seep a small amount of cold air. Further, I can feel some cold air around the edge of the radio opening, as well as between the steering column and the knee breaker panel. The heater does not get as warm as I think it should either. An suggestions before I get started troubleshooting?
Thanks!
Jeff Triplett
Old Jan 30, 2004 | 09:18 AM
rcy's Avatar
rcy
Make sure the fresh air control lever is in the bottom position. It's the lever to the left of the climate control. The top position should have little blue wavy lines beside it, indicating fresh air coming in. The bottom position should have just the little stick man.
Old Jan 30, 2004 | 09:39 AM
jtriplett's Avatar
Thanks rcy! The lever you mention is stuck and will not move. Looks like it is time for some closer inspection on my end.
Thanks!
Jeff T.
Old Feb 16, 2004 | 05:11 PM
Maxim/A\ttitude's Avatar
Did you ever figure out what was causing that to stick? I'm having the exact same issue on mine, figured I'd see what you came up with before I try to dig into mine next, hehe.
Old Feb 16, 2004 | 05:29 PM
internetautomar's Avatar
mod or sell?
Originally Posted by Maxim/A\ttitude
Naptown?
sounds like a sleepy little town
Old Feb 16, 2004 | 05:58 PM
It is...in the heart of IndiaNAPolis
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
