yet another new mod for the max
Old Feb 10, 2004 | 07:17 PM
mtcookson's Avatar
Bought Sola's (lophix) flywheel and tranny over the weekend to compliment the new clutch and gain some more power.
are the torque specs the same for the flywheel bolts being aluminum? hopefully i'll get this thing installed if i can get the upgraded input shaft bearing from ipt.
Thanks again Sola!
Old Feb 10, 2004 | 07:28 PM
subs1000w's Avatar
upgrade input shaft bearings ?? i wasnt aware there were such a thing
whats ipt
Brad92SE's Avatar
Looks good! I just installed mine this weekend and torqued the bolts to ~20 ft-lbs.
Old Feb 10, 2004 | 07:40 PM
MrGone's Avatar
20ft-lbs? I thought it was supposed to be alot more than that? I dont remember.
He's missing 2 bolts anyway
Old Feb 10, 2004 | 07:44 PM
mtcookson's Avatar
IPT = http://www.importperformancetrans.com/index.shtml
part of an e-mail i got from them:
"As well as some other performance upgrades, we have a means of installing a heavier duty bearing into the Nissan 5 speeds, which normally is a permanent fix."
I sent another e-mail to them to see if they would sell the bearing itself. Hopefully they will because this tranny crap is getting ridiculous and i don't have the money to have them build it up yet.
subs1000w's Avatar
i thought i tourqed mine to more like 80ft lbs
Old Feb 10, 2004 | 07:47 PM
subs1000w's Avatar
im very interested in seeing the out come of these and a price since my input bearings are making all kinds of noise good luck
Old Feb 10, 2004 | 07:53 PM
mtcookson's Avatar
i'll definitely let everyone know if they sell these outright. since they said its usually a permanent fix i bet there'd be a lot of maxima owners that buy one.
also, i think the fsm says 83-93 ft lb... but that just doesn't sound right to me.
Old Feb 10, 2004 | 08:01 PM
Matt93SE's Avatar
STFU n00b!
torque spec on the flywheel-->crank bolts is like 65ft-lb.
torque spec on the pressure plate-->flywheel bolts is around 22 ft-lb.. check your service manual for specifics.
(The flywheel-->crank specs are in the engine mechanical section. EM-35 in my 93 FSM. it's in the exploded diagram of the entire block.)
mtcookson, PLEASE let me know what you find out on the input shaft bearings. I replaced the entire tranny at 165k miles, and the bearings are shot again 35k later. this is ridiculous.
Old Feb 10, 2004 | 08:15 PM
mtcookson's Avatar
Will do
(owned by 10 char)
Old Feb 10, 2004 | 08:20 PM
lophix's Avatar
Matt, why am I not suprised?
It's so cool having someone closeby who can drop a tranny in less than an hour! Props, Mark...never seen anyone take that thing down like nothing.
Bearings will most likely be go...for once, someone actually KNOWS there's a problem with our trannys. I can't imagine what their (ipt) beefed up rebuilds would be like.
Old Feb 10, 2004 | 08:28 PM
Brad92SE's Avatar
Yeah, I was talking about the PP to flywheel bolts since they thread into the aluminum. Just curious, are the bearings in our trannies prone to failure? What are some of the symptoms?
Old Feb 10, 2004 | 08:34 PM
mtcookson's Avatar
the input shaft bearings are made of aluminum foil or something because they are always breaking. if you hear nasty noises when the clutch pedal is out and the engine is just idling most of the time the bearing is toast.
Old Feb 10, 2004 | 08:37 PM
mtcookson's Avatar
Thanks! Starts getting really easy when the input shaft bearing breaks every few months
Old Feb 10, 2004 | 09:56 PM
Fatty McFAts's Avatar
[QUOTE=lophix]Matt, why am I not suprised?
that'll make it easier to take the engine out :-)
Old Feb 10, 2004 | 10:11 PM
mtcookson's Avatar
much easier. if you lift the car a tiny bit more you can actually just lower the engine down. by doing that you don't have to unbolt the motors mounts. just hook up the hoist to the engine and lift it up a bit. then, just unbolt the cross member and slowly lower the engine. (this of course is after unhooking all the vacuum hoses and wires and such but you get the idea)
Old Feb 10, 2004 | 10:13 PM
lophix's Avatar
are you taking notes, t?
Old Feb 10, 2004 | 10:35 PM
vwink182's Avatar
Oh too true....that noise scared me! [and rightfully so!]
Old Feb 10, 2004 | 11:05 PM
mtcookson's Avatar
oh yeah, i got the flywheel resurfaced tonight for 20 bucks!
once i get that bearing, if i can, i'll get these things in and give everyone my thoughts on them (which i'm sure will be good)
Old Feb 11, 2004 | 09:10 AM
icepick's Avatar
ask mr gone he knows about torque
Old Feb 11, 2004 | 09:17 AM
MrGone's Avatar
hahaah
so whens the scheudled install date, Mark?
Old Feb 11, 2004 | 09:35 AM
mtcookson's Avatar
i'm hoping to have it installed by next week. still waiting on IPT's e-mail. wish i had a phone here i could use
Old Feb 11, 2004 | 12:45 PM
mtcookson's Avatar
alrighty guys, i just got off the phone with IPT (broke down and just used my cell phone. hopefully won't cost too much since i'm in roam here).
apparently what they do is they actually mill out some material where the stock bearing goes and put in a bigger one that is stronger so its not a direct replacement bearing.
i'll get a price quote and see what kind of price we'd be looking at but more than likely it will be quite a bit.
Old Feb 11, 2004 | 12:47 PM
lophix's Avatar
dang. but that does sound like something worth while.
Old Feb 11, 2004 | 12:52 PM
mtcookson's Avatar
yeah, finally having a somewhat strong tranny... i'd pay a pretty penny for that.
Excalibur23
Oct 13, 2015 04:33 PM
ballerchris510
Sep 23, 2015 08:46 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Pixel
Sep 15, 2015 05:53 AM
