missing when cold and more...
Old Feb 16, 2004 | 11:15 AM
mtcookson's Avatar
For some reason my seems to miss really bad when I start it up when cold outside. It misses at idle but I've also revved it to around 3000 rpm and it was still missing. Any ideas what the problem could be?
Also, when I let off the gas while driving around I get the nasty ricer "pop pop" sound when the engine's revs are going down. Is this a sign of running rich or lean? I would think it would mean I'm running rich since there would be a lot of unburnt gas in the exhaust but I've also heard running lean causes nasty popping noises so now I have no clue which it would be. Anyone know for sure?
Thanks in advance
Old Feb 16, 2004 | 01:13 PM
mtcookson's Avatar
oh yeah. also, anyone know why my car would just act like its giving no power up around 5500 rpm? when i run first gear out it almost feels like the rev limiter kicks in around 5500 rpm. its really annoying and i can't figure out what the problem is.
Old Feb 16, 2004 | 01:57 PM
internetautomar's Avatar
mod or sell?
Distibutor going bad.
Old Feb 16, 2004 | 02:03 PM
mtcookson's Avatar
just checked the distributor cap. there is a crack near one of the electrode thingies. i'll go crab a new cap and see if that helps.
Old Feb 17, 2004 | 07:29 PM
mtcookson's Avatar
could a vacuum leak do this as well?
Old Feb 19, 2004 | 09:53 PM
mtcookson's Avatar
got the distributor cap and it didn't help the missing at idle.
Old Mar 20, 2004 | 09:48 PM
Maxone's Avatar
missing at Idle and rpm range
It's could be your timing is off. I've seen a few where the timing belt
actually slips a tooth or two on either cam sproket. That will definetly
make it the engine miss and backfire. Set your crank to the 0-degrees
BTDC. Then remove the top T-belt cover and make sure the markings
on the cams are lined with the marks on the backing plate. If not, then
your timing belt has slipped. Good luck. Vacum leak won't make it backfire.
Old Mar 20, 2004 | 11:20 PM
MrGone's Avatar
is it just the popping kind of noise you hear in the exhaust? Well not so much popping but a spuddering kind of noise?
Old Mar 21, 2004 | 05:31 AM
4signs's Avatar
Thanks in advance
tru checking your plugs, I had a bad plug a while back and during boost I would back fire and miss
Old Mar 21, 2004 | 06:05 AM
CandiMan's Avatar
Say Candyman 5 times
You mentioned it's missing when cold, do you have these problems after it's at operating tmep? It sounds like a ignition related problem. You need to check your entire secondary ignition system for signs of arching. Components being cap (that's already changed), rotor, plugs, wires and possibly ignition coil.
Also, if you can find a dark place (away from the city lights, the darker the better) pop your bonet and see if you see any arching. You might see the actual spark arching to ground all over the place. Check at idle and at higher rpm.
MIKE
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
rbaker100
Sep 25, 2015 07:52 PM
