WEIRD, outside temps effecting engine.
Old Feb 20, 2004 | 12:26 PM
csid's Avatar
In the morning I start up my max (1990) and it runs great all the way to work. Once It warms up outside to 70-75 or higher it trips out. The engine will run extremely ruff and you cant even move. If you push the gas it will choke. Once it warms up all the way it will drive and actually rev up normally but still running a little ruff occasionally. Im thinking this could be some kinda sensor or something but I have know idea what it is. Any ideas?
Old Feb 20, 2004 | 12:31 PM
internetautomar's Avatar
mod or sell?
coolant temp sensor would be my guess.
Old Feb 20, 2004 | 12:34 PM
Seyath's Avatar
Brian is probably right. When the temperature gets high, your sensor misreads the temperature and starts choking your engine in order no to overheat the coolant. Check that before you try anything else.
Old Feb 20, 2004 | 12:43 PM
subs1000w's Avatar
if your car is an automatic and its not your coolent temp sensor id check the tranny
does it rev fine in nuetral and park or does it hesitat no matter what
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
