93 GXE -- Lumpy Idle/Faulty fuel gauge
Old Feb 21, 2004 | 03:21 PM
MAXIN's Avatar
Lumpy idle:
Idle lumps sporadically when engine is cold or warm. Feels like it wants to die once its warmed up. However, it runs smooth once your driving. The lumply idle only seems to occur when stopped and foot is off the gas pedal.
Fualty fuel gauge:
Appeartly when the fuel level reaches half a tank, the guage needle drops below E. It reads fine at any level above half.
Any suggestions (this is for my bro's '93 GXE)?
Thanks in advance.
Old Feb 22, 2004 | 11:18 AM
MAXIN's Avatar
Bump.......
Old Feb 22, 2004 | 11:38 AM
longjuanfeng's Avatar
Try cleaning out the IAC valve and do a general tuneup for the idle problem. Don't know about the fuel gauge.
Old Mar 2, 2004 | 11:37 AM
mehul's Avatar
Similar problem - rough idle
Hi,
I have a rough idle in my 93 maxima GXE, with 120 K miles on it. the car idles rough only in Drive or Reverse. As soon as I change to Park or Neutral, it becomes smooth again. When in motion, i.e. when the accelerator is pressed even a little bit, the roughness goes away. The rpm when the car is cold is >1000 both in Drive and Neutral. Its not rough then. When its heated up nicely, the Drive idle rpm is 600 and Neutral idle rpm is 700.
I had 2 injectors replaced last August, and the engine does not miss at all. The pickup is what you'd expect from a nissan v-6, albeit slightly on the slower side due to the heavy mileage on the car. I use an injector cleaner every 4-5K miles. I had a tune-up last August when the spark plugs were replaced, but probably not the wires.
A mechanic told me yesterday, that the idle rpm in Drive and Reverse is too low, that it should be slightly higher, and that if it were, the car would be smooth when idling.
Can you give me your rpms at idle, in Drive, when engine is cold, and then when hot?
Old Mar 2, 2004 | 09:58 PM
Maxdude's Avatar
longjuanfeng
How does one clean the IAC? Because I'm having the same problems as others here with the jumpy idle.
thanks
Old Mar 2, 2004 | 10:40 PM
MrGone's Avatar
the fuel gauge issue could be either the gauge itself or the fuel level sender. If your interested I have a spare set of GXE gauges that I can sell you .
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
