regular E36 vs. projector E36
Old Feb 23, 2004 | 09:55 AM
bigmax90's Avatar
can anyone give me a little advise on the difference of the regular E36 lights and the projector E36 type install. I have the install directions on the standard E36 light assemblies, but is there much difference in the projector/DDE assembly. tighter fit, more cutting, will they work. I appreciate the feedback. If someone has succesfully done the projector/dde pics would be great!
Old Feb 23, 2004 | 10:01 AM
D-sta's Avatar
One thing is that the projector unit is much bigger as its biggger in depth. Also the bulb sizes are different, the U.S. spec lights use a 9006 and 9005 while the projector ellipsoida by ZKW uses H1 bulbs. Also the U.S. spec lights are plastic while the ellipsods are glass. Wiring should be about the same amount of work just that they use different bulbs.
Old Feb 23, 2004 | 04:59 PM
Brad92SE's Avatar
Pics
(note- these don't have angel eyes)
Old Feb 23, 2004 | 11:04 PM
Drrrive's Avatar
Very clean Brad, mine isn't that clean inside!!
Old Feb 24, 2004 | 12:55 PM
Brad92SE's Avatar
Thanks! The biggest problem though is that mine tend to fog up a little. I guess when it warms up I'll have to go around em with the caulk.
Old Feb 25, 2004 | 12:57 AM
nubiannupe's Avatar
OG Maxima.org Member
I have that same problem, Brad! But most of that is because I've had to 'crack open' the casing to replace the bulbs on my angel eyes, and didn't seal them back all the way in a spot or two.
Oh, well... just means that warm weather will mean pulling those puppies out yet AGAIN.
Old Feb 25, 2004 | 07:42 AM
rrrfoma's Avatar
... and check if that "breather" at the back of the headlight is still in -
I forgot to put back one of those in the headlight and it was the cause of "cloudiness" in it. Just a thought.
Also I'n going to put "blackout tape" over silicone for additional seal - just in case.
Old Feb 25, 2004 | 09:53 PM
Delvin's Avatar
The euro spec E36 headlights require alot more cutting and if you are up to it the extra light output and looks is worth it. I've made a few Bimmer guys say 'Those are the headlights i want and you got them on Maxima???'
KabirUTA13
19
Oct 17, 2015 02:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
05RLS2
Sep 27, 2015 09:24 PM
foodmanry
Sep 24, 2015 12:02 PM
Vistance
Sep 17, 2015 05:17 AM
