removing abs
Old Mar 1, 2004 | 06:17 AM
mtcookson's Avatar
removing abs
How hard do you guys think it would be to remove that big hunk of abs junk on the passenger's side of the engine bay? Since one of my sensors are bad and I don't feel like paying 175 dollars for one I'm just planning on taking that thing out if possible so I can free up some room for an intercooler idea that I have. If i did remove it would I just run the brake line directly to the wheels or is there some sort of distribution block located somewhere on the non-abs Maximas? Thanks in advance!
Old Mar 1, 2004 | 06:27 AM
Matt93SE's Avatar
STFU n00b!
uhhhhhh, I wouldn't touch that one with a 100ft pole. either fix the sensor, or deal with it. removing the ABS would be a total nightmare.
Old Mar 1, 2004 | 08:12 AM
tmuscedere's Avatar
The place that I got one of my sensor's from was Felton's Nissan Auto Parts. If I remember right he charged $35 bucks shipped to Canada.
Here is the link
http://www.feltonautoparts.com/
Old Mar 1, 2004 | 08:24 AM
mtcookson's Avatar
i don't even want abs really and since i'm not using i figured i'd take that thing out to save weight and also give me some room for the intercooler idea. i'll take a peek at it and compare it with my gxe which has no abs to see what i'm getting into.
Old Mar 1, 2004 | 09:18 AM
subs1000w's Avatar
youd proboly have to change ALL the breake lines and maybe the master cylinder
Old Mar 1, 2004 | 09:22 AM
Jeff92se's Avatar
I'm needing a caw
It's not that easy(ie.. just taking the abs actuator out). The main brake lines are plumbed into the actuator. So you would have to rig a bunch of bypass lines. Note how many lines are plumbed into the master cylinder. Then you will go Also ABS equipped maximas have their porportioning valves inside the actuator. Non-abs maximas have the valve inside the master cylinder. You could easily swap MCs but then you have to probably totally re-plumb the brake lines.
Don't know about you but it's out of my confort zone.
Old Mar 1, 2004 | 10:11 AM
ACEGTRSKYLINE's Avatar
BAD IDEA trust me u dont want to mess takin out abs its a lot more than just abs unit. There are sensors valves brakelines and some abs units use a different master cylinders. Not unless u know exactly what u r doin u dont want to mess with it.
Old Mar 1, 2004 | 10:13 AM
Jeff92se's Avatar
I'm needing a caw
No way. I don't believe you one bit.
Old Mar 1, 2004 | 10:16 AM
mtcookson's Avatar
yeah, i figured i'd have to replumb everything
Old Mar 1, 2004 | 02:16 PM
the valves are actually in the hcu so u dont have to wry bout that but u can read this to learn more on abs.file:///C:/Ford%20Training%20Publications/selfstudy/Antilock_Brakes.pdf
Old Mar 1, 2004 | 02:20 PM
Jeff92se's Avatar
I'm needing a caw
I don't need to read nutin'. I was making fun of you because you just repeated what everyone else already said.
Old Mar 1, 2004 | 02:21 PM
didnt work let me try that again
file:///C:/Ford%20Training%20Publications/index.htm
copy and paste into web address and look at abs theory and operations.
i still dont know if this works but ill try to paste some pages from the book to the thread when i get home. I think this might be on just the schools comp but i have the disk of books at home i can use if it doesn't work.
Old Mar 1, 2004 | 02:23 PM
oh sry I just looked at the top post and type in my response sry
Old Mar 1, 2004 | 02:24 PM
Jeff92se's Avatar
I'm needing a caw
BTW. Stop trying to post links from your computer. Doesn't work that way.
Old Mar 1, 2004 | 02:27 PM
found that out sry
Old Mar 1, 2004 | 06:03 PM
internetautomar's Avatar
mod or sell?
Master Cylinder with ABS :
Master Cylinder without ABS
if you get a donor car the job ain't too bad, other wise pull ALL the ABS fuses and the bulb in the dash and keep driving.
Don't leave the ABS active with a bad sensor.
There have been instances where the ABS activated with a bad sensor and ended up with the car stopping in the middle of the intersection because it detected wheel lockup when there was none.
Old Mar 1, 2004 | 08:14 PM
mtcookson's Avatar
i'll see what i can do on the donor car becuase i'd really like to get rid of it since i'm sure its pretty heavy and i need that part of the engine bay really bad. i'll take a look at it and if i end up trying it (and accually getting it finished) i'll try getting a write up of some sort.
Old Mar 1, 2004 | 08:23 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i have to agre with everyone here also DONT TOUCH THE ABS !! just get a sensor and be done with it.
Old Mar 1, 2004 | 08:26 PM
mtcookson's Avatar
the thing is, i don't want it period. i need the spot that its sitting on to be clear. if i can't do it i'll just leave it how it is because i don't even want the abs to be working.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
jaydot901
Sep 29, 2015 01:18 PM
