weak or clog injector
Old Mar 8, 2004 | 10:04 AM
maximagxe90's Avatar
Hi,
a weak or clog injector a 91 octan would be recommend,
because i put the 91 octan into my car and it seem fine,
seem like the fuel injector were clog,
Old Mar 8, 2004 | 07:26 PM
boosted3rdgen's Avatar
try some fuel injector/system cleaner...a 7 dollar bottle could save you from buying a new injector or stop it from causing future/serious problems
Old Mar 8, 2004 | 09:59 PM
Hi,
i tired a 3 dollar bottle and seem to help the car, but it will come back,
what would you recommend for a cleanning solution to clean the fuel injector?
Old Mar 8, 2004 | 11:52 PM
zach_denver's Avatar
The octane rating of your gas will not benefit your injectors...
I'm going to get flamed for this, but there's a misconception that "premium gas" is better -- it's not, it just takes more pressure to cause it to combust.
With that said, IT IS recommended that you use premium in the maxima, but I don't, my parents/brother hadn't used it for 12 years and my engine runs great. (The timing may be retarded as a result, but the difference is negligable.) (I tried premium after having the battery disconnected and didn't notice a difference.) The compression ratio on a max appears low enough to safely use regular or midgrade.
Now watch everyone flame me...
If you want proof check out this article (notice the quote from Jim Blenkarn (Nissan Powertrains)
http://www.tripinfo.com/ITM/Articles2003/ITM456.html
Also here's an interesting article about octane:
http://auto.howstuffworks.com/question90.htm
Old Mar 9, 2004 | 12:29 AM
MrGone's Avatar
Watch out what additives you put into your gas tank/crank case, if they have teflon in them do not use it (ex. the Z-Max engine treatment stuff). I only use Seafoam and Marvel Mystery Oil.
Also Zach, your right about that, the higher the Octane the slower the gas burns.
Old Mar 9, 2004 | 08:18 AM
Hi,
would a slick 50 help the fuel injector?
or any 2 or 3 dollar bottle help?
Old Mar 9, 2004 | 02:11 PM
MrGone's Avatar
I would have to go look at the bottle, but like I was saying I only use Seafoam and MMO, seafoam mainly just for the intake, MMO for the crank, and then flip a coin for the gas tank
Old Mar 9, 2004 | 02:13 PM
hi,
do you use both for the fuel injector?
Old Mar 9, 2004 | 08:18 PM
Originally Posted by maximagxe90
Hi,
Maybe, but probablly not, I have heard from some people that techron is the best intake additive you can buy, but there's a lot of assumption and hear say regarding such matters. 3M makes an aresol product that connects to fuel line --my dad use to own an econolube so I got this done cheaply and is actually worked!
However, conventional wisdom is that anything that can clean out an injector will also damage the injector (plus you're likely to redeposit all the cra.. you have between the gas tank and the injector (especially if you have an old fuel filter.) Also, if your injector is completely clogged there is almost no chance anything you put in the tank will reach the injector.
Despite all this, I would probablly try the $3 bottle (or try the seafoam or whatever...) and see what happens, you're next option would be to replace / ultrasonically clean your injectors anyway so why not? I would (and have) also change(d) my fuel filter before putting any injector cleaner in your tank total cost? $13 and changing the fuel filter in a good practice anyway.
Old Mar 9, 2004 | 10:22 PM
Hi,
i already change my fuel filter,
my fuel injector are sometimes clog and sometimes not clog,
when i put the stuff in my tank it sometimes help the injector, and sometimes didn't help the fuel injector,
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
