Does not run
Old Mar 13, 2004 | 06:25 PM
phoneman's Avatar
Does not run
I have a 89 max, fuel inj., car does not run, at first it would
start and run cold but after warming up would not start, i checked
fuel pressure, had 40 psi at key on, replaced coil, module,cap rotor
had timming belt replaced 3000 miles back still comes up on TDC,
did dignostic on ecu showed no codes, has spark at plugs not real
blue in color, and spark is not consistent. thinking its a bad ECU
engine will turn over with startrer, has new exhaust system 3000
ago
Old Mar 13, 2004 | 06:41 PM
subs1000w's Avatar
try crankshaft positioning sensor
Old Mar 13, 2004 | 07:11 PM
phoneman's Avatar
ok, I try that next, is this locatde in the distrbtor like a pick up coil?
Old Mar 13, 2004 | 07:30 PM
internetautomar's Avatar
mod or sell?
What do the plugs look like?
Old Mar 14, 2004 | 04:06 AM
phoneman's Avatar
I replaced them during this problem, old set was dry and
no oil present on plugs replaced with V- Grove ngk
Old Mar 14, 2004 | 05:23 AM
mod or sell?
were they white? black? grey?
I'm only refering to the tips of them here.
Old Mar 14, 2004 | 06:25 AM
phoneman's Avatar
They were white to gray, looked a little lean on the cramic part.
Old Mar 14, 2004 | 09:25 AM
mod or sell?
do your o2 sensor if it hasn't been done within the last 30k.
Old Mar 14, 2004 | 09:51 AM
phoneman's Avatar
Just testing control module with meter according to chiltons manual,
both old and new check the same which is bad according to the manual,
I have no counity between a & B , a & c a=+ lead on meter
I have counity between a & b , a & c A= - lead on meter
is this the correct way to check?
I thought the o2 sensor would only make it run rough, this thing
will not run at all.
Old Mar 21, 2004 | 06:45 AM
phoneman's Avatar
This was the problem, it is located inside the distribtor.
I've never had one work part of the time then quit like this one.
The shaft int dist. had rough places that were tight to turn,
like ti was trying to seeze up. It runs again.
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
