Help, Door lock not working
Old Mar 17, 2004 | 08:03 PM
Nmax92's Avatar
I need some help. My passeger front door lock isn't coming up when I press the disarm button on my alarm transmitter. The other doors' lock come up. what the h-ll could it be?
Old Mar 18, 2004 | 10:42 AM
internetautomar's Avatar
mod or sell?
could a bad actuator. or wiring.
Old Mar 18, 2004 | 04:18 PM
zerphyte's Avatar
i would take the panel off first and make sure no wies have came loose from theyre solder'ed housing on the circuit board. if they haven't chances are the actuator is bad(like internetautomar stated) if wire's have came loose, if you can solder, just solder them back on theyre(use some flux paste if needed) or ask around, i'm sure you have a friend that knows how to solder.
Old Mar 19, 2004 | 11:35 AM
CiViCKiDD's Avatar
I've got a problem with my locks too (not exactly the same as your though) --- in my '93 GXE, sometimes my power locks work and other times they don't. When the power doorlocks work, I can't open the door with the key (I have to punch in the security code) and then the locks open.
I've gotten kind of used to it, but if its a cheap fix (and anyone here knows what's going on) i'll take a look at it...
Old Mar 19, 2004 | 11:41 AM
icepick's Avatar
under the dash drivers side is the brian for the power locks
King_Ten_Ahead
Sep 30, 2015 04:27 PM
rbaker100
Aug 31, 2015 11:09 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
