Considering a 92+ SE, question about VTC
Old Mar 20, 2001 | 09:12 AM
Hello,
I am new to this site, and was referred to it for good info. I am considering buying a 92+ SE w/ manual tranny (190 horses being the main reason) as I've always liked those Maximas, they're fast, have got a decent audio system, and are generally reliable. However, I recently heard about the problem of the VTC sprockets failing. My questions to you guys about this are:
1. Should I avoid a Maxima of this generation, and look for a newer or older one?
2. Is this a LIVEABLE problem or is it something that I should avoid because of longterm damage, repair costs, etc.
3. I only have about 6K to spend, so I'll probably be getting a 92. Are there major differences between 92, 93, 94? As far as I know it's only minute cosmetic differences.
4. What other problems should I expect, and what should I look out for when going to look for a 3rd gen Maxima w/ the 190 horse engine.
5. What would you suggest the first modification be?
Old Mar 20, 2001 | 09:16 AM
Jeff92se's Avatar
I'm needing a caw
If the engine is quiet, then they are probably okay. Most guys here just leave them ticking anyway. If you get a quiet one, make sure to change the oil and use synthetics. At this time frame, the 92-94 SE's are about the same. But the 94 is supposed to have upgraded versions of the VTC. But if you SE has had the VTCs done already, it will have the upgraded ones anyway. The first mod should be a rear swaybar, then shocks/springs, then Y-pipe/intake.
Originally posted by Anjapower
Hello,
Old Mar 20, 2001 | 09:26 AM
Another question: I've heard the VTC problem occurs during start-up, when the engine is cold. I live in Massachusetts, so it is cold right now, but I'll be buying this car sometime in May. Will a cold engine in a warm temperatures still click?
Old Mar 20, 2001 | 09:33 AM
Jeff92se's Avatar
I'm needing a caw
It depends on how bad they are. It's been along time since I fixed mine but here it goes. They will usually tick at start-up then go away. Then they will tick when you have parked the car for 1 hour+, then restart the car. Then it will eventually tick all the time.
Old Mar 20, 2001 | 09:53 AM
"Then it will eventually tick all the time."
Do you mean even after start-up? As in having it ticking while driving around??
Old Mar 20, 2001 | 09:54 AM
Jeff92se's Avatar
I'm needing a caw
Yup
Old Mar 20, 2001 | 10:01 AM
Crap. That sucks. Sorta turns me off from buying one, or saving up for a 94. How did you fix yours? Repair them or disable them?
Old Mar 20, 2001 | 10:12 AM
Jeff92se's Avatar
I'm needing a caw
I replaced them(not rebuilt or grounded) and at the same time, fixed the exhaust manifold studs, did a clutch job and did a head gasket. I took the engine out to peform all this.
http://www.zing.com/picture/p2df3683...2.jpg.orig.jpg
Old Mar 20, 2001 | 10:16 AM
So, would you suggest staying away from 92-94 SE?
Old Mar 20, 2001 | 10:24 AM
Jeff92se's Avatar
I'm needing a caw
Read my first reply.
Old Mar 20, 2001 | 11:58 AM
singhg83
well, from what i heard is that if you get a 92-94 se, you can get it in automatic with the 190hp & avoid the vtc problem
Old Mar 20, 2001 | 12:02 PM
Jeff92se's Avatar
I'm needing a caw
Nope. ALL 92-94 SEs have the VE30DE, which have VTCs. Now the autos DON'T HAVE THE POWER VALVE in the manifold.
Old Mar 20, 2001 | 12:09 PM
singhg83
oh my bad, but wat if u rewire it. there have been some posts on here sayin that you can just rewire it & everything is the same, is that tru?
Old Mar 20, 2001 | 12:12 PM
Jeff92se's Avatar
I'm needing a caw
I don't do rewires, sorry. I only do the correct fix.
Old Mar 20, 2001 | 02:14 PM
Czar's Avatar
Don't believe that the 3rd gen Maximas have great audio systems either. I have the BOSE, which does sound real good (way better than any aftermarket systems with </= 200 watts running no larger than 6 x 9 speakers), but only if its running right. Lately BOSe has been a nightmare for me. The 3rd gen BOSE amps are subject to failure, and I have had a couple fail in big ways. Yesterday, I was driving and one amp blew causing some VERY loud popping in the speaker, and the speaker was blown as well, one that I had just replaced. Anyways, right now I have two blown back speakers (some sound but lots of buzz), two blown rear amps(they are sporatic... sometimes they will work and other times I have no sound out of one or more speakers), and one bad front amp, as well as a broken CD player. All in all don't buy a 3rd gen based on the BOSE system. I will be soon ripping it out for an afteramarket system....
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
