Another DQ
Old Apr 13, 2004 | 06:10 PM
y2korean's Avatar
Another DQ
I'm replacing my front corner lamps and have removed them from my car. However, I'm having trouble removing the bulbs and their wiring unit from the casing. It seems to be attached at a point that slides onto the casing, but it's stuck or something. Is there any way to get this off, or do I just need to force it off?
<img src="http://www.auburn.edu/~garlabl/images/corner.jpg">
Old Apr 13, 2004 | 06:16 PM
xnyc's Avatar
a lil bit of wd40 and let it sit. then put some pressure while your turning. wipe off wd40 wen you get it off. dunno if its flamable
Old Apr 13, 2004 | 06:19 PM
y2korean's Avatar
no, no turning involved, just pulling. it's like there's a catch on the glide that won't let it come off.
Old Apr 13, 2004 | 06:27 PM
xnyc's Avatar
oops. thoought he meant headlights
Old Apr 13, 2004 | 06:29 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
yea there is a catch on the plastic just give it some convincing it will slide off.
Old Apr 13, 2004 | 06:33 PM
«§»Craig B«§»'s Avatar
there is a little "button" you can press on one side of the connector while pulling it apart
it's kind of hard sometimes so you can use a flat head screwdriver to push down on that piece while you pull it
