excessive play in steering
Old Apr 23, 2004 | 03:39 AM
jordanius83's Avatar
hello all,
i'm having a problem with way too much play in the steering on my 90se.
when i last had it in the shop, the tech told me that it was a bushing that connected the steering column to the firewall? but in the FSM, it only lists bearings and tie rods as possible culprits.
any suggestions on where i should start?
Old Apr 23, 2004 | 11:31 AM
eric93SE's Avatar
Originally Posted by jordanius83
hello all,
Just a suggestion, check the belt tension.
Old Apr 24, 2004 | 05:34 AM
goon9's Avatar
I noticed some play in my wheel last night too. Probubly about and inch, I thought it my be my alignement because the struts are dieing.
Old Apr 24, 2004 | 05:59 AM
Matt93SE's Avatar
STFU n00b!
improper belt tension won't cause play in the steering wheel.
In orter to find the problem, you're going to need two people.. crawl under the car and have the other person turn the wheel back and forth (1/8 - 1/4 turn is plenty. just enough to make the system move)... grab onto the rack where it mounts to the firewall, and grab onto the tie rod ends where they join the spindle... you will be able to feel where the play is in the system.
It could also very well be the ball joints. if the car has 100k+ miles on it and you've never changed them, it certainly won't hurt to do it while you've got the car apart. an extra 30 minutes and $75 in parts will save you from having to get another alignment when you replace those.
Old Apr 24, 2004 | 06:00 AM
xnyc's Avatar
http://www.autozone.com/servlet/UiBroker?UseCase=S001&UserAction=viewSimpleDiagRes ultsInfo&Parameters=Front+Of+Vehicle|~24|~Driving| ~22|~Play+In+Steering|~136|~Feels+like|~1&FROMJSP= type
this doesnt apply to EVERY car cuz other cars might have more stuff but most of it does. hope this helps
Old Apr 24, 2004 | 06:01 AM
xnyc's Avatar
sry its not a link just select the whole thing and paste it
Old Apr 25, 2004 | 12:59 AM
matt, how often do you get the chance to come back up to tulsa, if ever?
Old Apr 25, 2004 | 07:47 AM
89badmaxse's Avatar
my 89 had play in the wheel and when i replaced my rack i replace the knuckles and the play went away so you may also have the same problem mine did just a thought might wanna check into it
Old Apr 25, 2004 | 03:32 PM
maxi1's Avatar
had the same problem recently Two bushings he sprobably right. carefull on the highway mine swerved like hell
Old Apr 25, 2004 | 09:11 PM
Matt93SE's Avatar
STFU n00b!
I still head back every couple of months. I'm going to be heading up there again sometime mid-may to meet with some friends and see family..
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
uttadms31
Sep 30, 2015 05:24 AM
Andy29
Sep 29, 2015 05:32 AM
