Intake removal
Old May 1, 2004 | 07:49 AM
dod.albino's Avatar
Intake removal
Looking at the job before starting. Even though Nissan manual and Haynes make no mention of it, it would appear that the EGR valve needs to be removed from the intake in order to get the itake out. Can anyone confirm this?
Also, what do you do about the IAC/air cut valve? This is hard wired without a connector. Should it be removed from the intake before removing the intake or cut the wires and leave it attached or some other approach?
Thanks for replies.
Old May 1, 2004 | 09:16 AM
jwmaxse's Avatar
I was about to try to answer your question, but I don't know what kind of car you are driving. Is it the SE or GXE? Either way you shouldn't need to cut any wires just to take off the intake.
Old May 1, 2004 | 09:25 AM
dod.albino's Avatar
Its a GXE
car is a GXE. i agree, makes no sense to gave to cut wires. the IAC could be removed i uppose but is there another way?
Old May 1, 2004 | 09:49 AM
subs1000w's Avatar
there is a conector somewhere you just have to find it
Old May 1, 2004 | 06:03 PM
Evil_Twin's Avatar
Took me about 10mins to get all my rusted bolts and junk out. I never knew there really were wires other than the MAF... I think thats what its called?. but that was the only thing I unplugged...
Goodluck. Took me a total of 4hrs.. 3 hrs to cut a HUGE hole, but other than that... it was quick.
Old May 2, 2004 | 07:59 AM
90SEBlack's Avatar
What does GXE or SE have to do with anything, The question would be do u have a VG or a VE and there shoudl be a connector but its 8 - 10 on the other end of that wire that comes from the iacv.
Old May 2, 2004 | 08:07 AM
DMad8724's Avatar
you know you have a GXE right 90SE?
Old May 2, 2004 | 12:42 PM
90SEBlack's Avatar
The car was oroginally a GXE it is now a SE with all options expect Tire Flaps that an SE of the same year had.Look at my cardomain site!
Old May 2, 2004 | 01:40 PM
dod.albino's Avatar
its a vg, single cam, if that makes a difference
it's a vg, single cam, if that makes a difference
Old May 2, 2004 | 02:19 PM
jwmaxse's Avatar
Sorry, 90SEBlack, I shoudle reely reread what I rite 8-10 be4 I post nything, It woudle probly be esier to reede and understand.
dod.albino-did you ever get it taken apart? I can't say for sure because I don't have a VG motor, but I would think that if neither of the manuals say anything about it that you can just leave the EGR on and remove the piping going into it, that's what you have to do on the VE.
Old May 2, 2004 | 02:20 PM
Maxmus_X's Avatar
SHIFT_PANTS
Huge difference, but this isn't my department
Old May 2, 2004 | 04:11 PM
DMad8724's Avatar
also GXE wheels. chrome trim...hehehe
Old May 3, 2004 | 06:44 AM
tmuscedere's Avatar
No you dont have to take off the EGR valve to do the injectors, just remove the 2 nuts on the side of the IAC valve. If I remember right it was 2 12mm nuts
James92SE
142
Jan 2, 2024 09:23 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
