coolant leaking
check ur hoses like ur upper radiator hose, bypass hose which goes into ur water pump and any other hose that u can think of. this happened to me and it turned out to be the upper radiator hose and bypass hose.
good luck
good luck
Originally Posted by MrGone
Inside the car or outside? Hopefully outside.
when was the last time the pump was replaced? how many miles on your car? i noticed a little bit leaking from mine too..kinda need to get around to replacing the pump and seal. i think if coolant gets on the rubber belts, it'll deteriorate them faster.
If it makes you feel better, mine is doing the same thing. Dripping on the pass side, off the pass control arm. I am nearing 120K, so I need to have the tbelt and water pump done-but I will also look at the hoses. I've had a slow loss, but I have noticed it running an inch?? low in the radiator itself-so I recommend checking your radiator tank when cold.
litch
123
Jan 4, 2024 07:01 PM
foodmanry
Sep 24, 2015 12:02 PM
Hdnseek
Sep 9, 2015 05:55 AM
