piston rings
Old May 11, 2004 | 01:33 PM
xilef's Avatar
piston rings
I felt intermittent vibrations while driving, I decided to check my spark plugs. One of the plugs turned out to be flooded with engine oil. I assume that the piston ring must have broke and now lets the oil through. How much would it cost to replace the ring? It seems like it would take a lot of man-hours disassembling the engine to get to the piston.
Old May 11, 2004 | 01:49 PM
MrGone's Avatar
woah there, dont jump the gun.
Run a compression test, also make sure all your injectors/coil(s) are working first.
Old May 11, 2004 | 01:54 PM
xilef's Avatar
I forgot to mention, I did run the compression tests. Everything checked out.
Old May 11, 2004 | 03:30 PM
mtcookson's Avatar
could be your pcv valve letting oil in
Old May 11, 2004 | 05:52 PM
subs1000w's Avatar
what about leaky valve seals
Old May 12, 2004 | 12:16 PM
internetautomar's Avatar
mod or sell?
How about oil leaking from the valve cover past an inadequate (sp?) tight spark plug.
But more likely the Valve stem seals IMHO
Apr 16, 2020 05:15 AM
6spd4dsc
Mar 4, 2016 05:19 PM
Pied
Sep 26, 2015 03:29 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
DBear
Sep 14, 2015 08:33 PM
