Looking for tranny swap suggestions
Old May 12, 2004 | 01:08 PM
jwmaxse's Avatar
I'll be replacing my tranny, clutch, Y-pipe, CAT and flywheel next week and I'm looking for any suggestions as to what else I should do while I am at it. Does anyone have any suggestions of anything else I should replace or anything I need to be aware of, especially regarding the tranny? What about seals where the CV shaft goes into the tranny?
FYI:the tranny is a JDM w/ 34,000 miles on it, and I have a FSM to help along w/ the swap.
Old May 12, 2004 | 06:22 PM
jwmaxse's Avatar
Have any of you guys changed your transmissions? I'm not asking for instructions, just helpful suggestions if you guys have any.
Old May 12, 2004 | 06:28 PM
subs1000w's Avatar
yup just replace the axle seals and if youve never replaced a clutch make sure when your installing the new one you use the alignment tool and torque all the flywheel and clutch bolts right
Scope's Avatar
Im izz sexay
You'll be better off with a parts car because the tranny might not come with all the little no-name parts. Plus with the parts car you won't need any help because it is all remove and replace. Try to find one from your local junkards. How much did the JDM tranny cost?
Old May 12, 2004 | 06:30 PM
subs1000w's Avatar
im pretty sure his car is already a 5spd so he doesnt need a parts car
Old May 12, 2004 | 09:03 PM
jwmaxse's Avatar
The tranny was $730 shipped, and yeah, my car is already a 5 speed, I don't believe in buying automatics
I've heard it's a good idea to do the rear main seal as well, so I think I'll order that and the axle seals. Is there anything else I need to know before I do this? A fellow .org member has a FSM and will be helping me with it since he is a little more experienced, even though he usually only works on a VG
Socalstillen
Sep 20, 2015 11:46 PM
catalinvint
Sep 16, 2015 07:48 PM
I<3 A32's
Sep 10, 2015 11:07 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
