5 spd and hot weather
Old May 12, 2004 | 01:21 PM
Bob92se's Avatar
We just had a couple of back to back 85-90 degree days. I noticed that after about 30 minutes of driving the car it becomes difficult to shift, especially getting it into first. Has anyone else had this problem? Any remedies? I know a tranny cooler would help but I don't have the cash right now. Any insight would be appreciated. Thanks
Old May 12, 2004 | 01:26 PM
jwmaxse's Avatar
They don't make a tranny cooler for the manual tranny. You should check the gear oil level on your tranny to make sure there is enough in there. Usually when your tranny is warm it is easier to shift, and harder in the cold, strange.
Old May 12, 2004 | 01:46 PM
Jetman7060's Avatar
Yea Tranny coolers are for Automatics. If it seems like that it more than likely because your riding the clutch mine did that when I was still kinda learning the clutch.
Old May 12, 2004 | 05:07 PM
Maxpwer's Avatar
No turbo, no care!
Get some synthetic transmission fluid like Red Line. I had trouble shifting into 1st for the past 10 years, I changed to synthetic and the problem is gone!
Old May 12, 2004 | 06:24 PM
subs1000w's Avatar
im pretty sure it has to do with the shifter linkage i have the same problem and it only started after i put my sts on and i have amsoil sythetic gear oil but i also removed my heat shield which could be why
do you have a sts ?
is your heat shield still in place ?
Old May 13, 2004 | 08:18 AM
MONSTERMAX's Avatar
I have a STS and my heat shield is removed. I have the same exact problem when my car warms up. I still havent found a solution yet. Maybe i'll change my tranny fluid and make sure there's enough in there!!!
Old May 13, 2004 | 12:54 PM
huy1224's Avatar
Sometimes, I can't get into first at all unless i release the clutch and press down on it again. Is this the same problem that you're experiencing??
Old May 13, 2004 | 02:34 PM
todamax's Avatar
I think its an STS issue. My parts car didn't do this, but my car does it now. THe only difference is the STS and new gear oil.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
ef9
Oct 4, 2015 08:43 AM
