rims problems
Old May 19, 2004 | 05:42 AM
goodfella776's Avatar
rims problems
i have some 19 inch rims on my 93 max GXE, i got a wheel alignment, all the wheels have been balanced, but i still dont know why the steering wheel shakes when i drive it on the freeway going about 60 mphs or higher. Any suggestions on what it would be?
Old May 19, 2004 | 05:52 AM
Michael's Avatar
Back in a 3rd Gen.
do you have hub centric rings on the wheels? not having them can cause vibrations. I know they do on mine.
You may have worn out suspension pieces that are amplified by the thinner tire and heavier wheel.
I had a shake and replaced all of my suspension except the tie rods and rack. I am going to try some rings on my wheels if I can find them and if I still have problems I am going to look into the tie rods...then the rack.
More than likely your control arm bushings are worn, strut towers are cracked and worn etc.
Old May 19, 2004 | 06:06 AM
aw89maxSE's Avatar
This doesn't have much to do with the thread, but I was wondering Michael if your car still looks like your sig pix or if you have painted or something. It's a dang nice car and I was just wondering if you have updated on it and if you got some pix.......those look like Lexus rims which are way hot
Old May 19, 2004 | 06:42 AM
ok fasho
thanks, i think im going to change both of my lower control arms, and the bushings in them, my last maxima i had to change the bushings because it was doing the same thing, but i guess i might as well change the whole arm
Old May 19, 2004 | 06:44 AM
Matt93SE's Avatar
STFU n00b!
His rims are nice, but the MGRs are better.
vibes at 60mph..
rear parallel link bushings
tie rod ends
ball joints
wheel balance
hubcentric rings
bent wheels.
you've got a few things to check there.
Old May 19, 2004 | 06:45 AM
Matt93SE's Avatar
STFU n00b!
I sell new control arms as well as rebuild old ones.
Old May 19, 2004 | 06:56 AM
internetautomar's Avatar
mod or sell?
Originally Posted by Matt93SE
I sell new control arms.
HEY! that's my line!
Old May 19, 2004 | 07:11 AM
Michael's Avatar
Back in a 3rd Gen.
Well it doesnt look like it does in the sig but its not painted either.
I have had a lot of stuff happen to prevent me from finishing...I will not go into that because its still a sore subject for me. I hope to paint it this summer.
Right now it is coated in black epoxy primer and does not have a single piece of weather stripping or anything else on it for that matter. I will be taking the doors off in a week or 2 so I can finally paint them on the inside and paint the door jams too. Then its just a matter of finishing the little bit of body work and paint the whole thing.
Believe me when its finished I will post pics and update my sig. I am tired of the multi color sig pic .
The wheels are Radius (Moda) R6 by the way. They will soon ba a different color...just not sure what yet.
Matt... ...I tried to get some MGRs (actually MAS but the same wheel) in 18s last year but the deal fell through because the person was too busy to answer PMs or emails much less take them off...or he just didnt want to sell them. I will one day have my RO_JA formula 5s in 18s though because these wheels are just too dang heavy.
Old May 19, 2004 | 07:51 AM
Matt93SE's Avatar
STFU n00b!
heh, yeah, I remember that Mike..
MAS Italy was the company that originally made the MGR wheel- I guess they were bought out or renamed to Voxx.. which is the name on mine.
Old May 19, 2004 | 09:36 AM
Michael's Avatar
Back in a 3rd Gen.
I think it is 2 different companies that make the same wheel design...I have even seen another company with a wheel just like it but I cant remember the name. I have seen that on other designs too. I know you can still find the MAS Italy "Presidents" but they may be left over stock or something.
Old May 19, 2004 | 09:41 AM
Jeff92se's Avatar
I'm needing a caw
I bet the rims are not hubcentric. So even if the rims/tires are balanced, it could vibrate.
I imagine these are just some generic multi-fit rims with some huge hub bore to fit everything from Nissan to Mitsubishi.
Old May 20, 2004 | 10:54 AM
ok well hope can i tell if the rim is hubcentric????
Old May 20, 2004 | 04:39 PM
mod or sell?
if the center hole has the EXACT same size as the raised lip on the center of you front wheel hub
alahjahwan09
18
Sep 21, 2015 09:12 PM
Serotta33
Sep 17, 2015 12:14 PM
0m3nc0w
Sep 11, 2015 05:21 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
