varibale Tming control solonoid
Old May 23, 2004 | 08:59 AM
dogboy's Avatar
any body HELP
Old May 23, 2004 | 09:01 AM
Cliff Clavin's Avatar
Way out West
exactly what do you need help with?
where it's at?
what it does?
how to ground it?
Old May 23, 2004 | 10:16 AM
dogboy's Avatar
All the above please?
Old May 23, 2004 | 11:45 AM
dogboy's Avatar
Say Red this info is needed to complete a costomers max my real claim to fame is V-TWIN
Old May 23, 2004 | 12:46 PM
lophix's Avatar
well i guess you're in a bit of a spot aren't you? a "customer's car"? are you a mech by profession and if so don'tyou have the service manuals needed?
Old May 23, 2004 | 01:13 PM
dogboy's Avatar
Volvo Tech At an after market volvo perf shop
Old May 23, 2004 | 01:21 PM
MrGone's Avatar
Originally Posted by Red92MaxSE
where it's at?
look by the oil cap on the front valve cover, right above it. There is a wiring harness sticking out of it. The valve cover vent tube is to the right of it and 'above' it. It is hex like in shape and about 3-4" long.
what it does?
It's grounded by the ecu which blocks an oil passage causing the oil pressure to build in the VTC assembly which changes the cam timing.
how to ground it?
You can either tap the wire at the ECU, or at the solenoid itself. If you tap it at the solenoid, its the yellow wire, which you want to tap into, not cut, and you ground it. You only have to do it to one of the solenoids since it is a shared signal wire.
(Chris knows all this, but it was just easier to quote him )
Old May 23, 2004 | 01:34 PM
Way out West
I know the answers, too, but I didn't know what questions he wanted answered.
Hey, Dogboy, do you work at that shop on 148th and Stark? (or is it Division). I used to live over there.
Old May 23, 2004 | 02:01 PM
MrGone's Avatar
Old May 23, 2004 | 04:27 PM
dogboy's Avatar
thank you for the information Red Kudos 2 u
Old May 23, 2004 | 06:09 PM
Way out West
what's wrong with the Maxima you are working on? Are the VTCs ticking or are you going to replace them?
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
