clutch fork or slave cylinder
Old May 25, 2004 | 01:59 PM
leo.c.'s Avatar
I have a 92 maxima 4dsc 5spd,the clutch has maybe 10K on it.The slave cylinder blew out on it.My friend put on a new one without installing the clutch fork boot.
Well,the new one blew,he says the fork is messed up and will have to replace the clutch.I say lets put another slave on with the boot installed and see what happens if it blows I'll just tell autozone some story about their junk being like forestcity autoparts.
The fork does wiggle around,but i have no idea if this is normal or not.I've never had to work on a manual transmission before.
Old May 25, 2004 | 02:04 PM
«§»Craig B«§»'s Avatar
the fork should not have much play in it
it should only move left or right and that should take some effort
if it moves up and down, that's not good
I just helped a friend replace a bad throw-out bearing last weekend. The fork felt really loose and moved around a lot. Once we got the tranny out, one of the "ears" of the TO bearing had broken off
You should definitely have the boot on the fork (the one that hold it to the tranny case) so do that first if you haven't already.
Old May 25, 2004 | 02:08 PM
leo.c.'s Avatar
Is that play with the boot on or off.It moves around with the boot off but side to side with the boot on.
Thanks for the info,
Old May 25, 2004 | 02:42 PM
That's with the boot on. I've never had the boot off while the tranny was still on the car. Definitely put the boot on though to prevent debris getting in your clutch and tranny.
Old May 25, 2004 | 07:49 PM
leo.c.'s Avatar
Yep,it moves just like a loose tooth.Guess I should replace everything while I'am at it.Should be about two days worth of fun and swearing.
Old May 26, 2004 | 05:27 AM
yeah, if it's that loose, I'd be concerned about the T/O bearing or the fork
it isn't all that hard, just takes some time - you need to remove the intake, battery and tray, slave cylinder, various harnesses attached to the tranny, starter, axles and then you can drop the tranny. Be sure to label the bolts that hold the tranny to the engine since they're different lengths
Matt93se has a writeup somewhere. I think it's on www.4dsc.com/articles
the hardest part is physically removing the tranny, it'd help if you had a tranny jack but it's not necessary
while you're in there, you should replace the rear main oil seal just behind the flywheel, axle seals, machine flywheel, maybe replace clutch and pressure plate, TO bearing
good luck
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
