Eibach camber kits
Old May 31, 2004 | 07:36 PM
TightBlack97's Avatar
Eibach camber kits
I have recently put some eibach springs on the Maxima. I had the alignment done and it seemed ok, but now I think I want to put the camber kit on. Plus I seem to hit every pot hole in Atlanta, GA that exist.
I did some research on pricing and the rear kit is like 4 times the price of the front kit!!!
Should I just buy/do the front or do the front and back?
I notice that I lose a little traction when I go on driving on the curves too. My tires dont help the situation either.
Matt make me some custom camber kits...lol
Old Jun 1, 2004 | 09:10 AM
internetautomar's Avatar
mod or sell?
the difference in price is because the rear is a link not just bolts.
Just be sure to buy them from me.
Old Jun 1, 2004 | 09:19 AM
mtcookson's Avatar
on those front adjustment bolts are the 2 degree ones 2 degress only or adjustable up to 2 degrees?
Old Jun 1, 2004 | 09:40 AM
mod or sell?
up to 2 degrees.
Old Jun 1, 2004 | 11:28 AM
MrGone's Avatar
so on the 2* bolts you can set them for 1*?
Old Jun 1, 2004 | 12:16 PM
mod or sell?
or 1.5* or 1.76746573772343773849*
Old Jun 1, 2004 | 12:17 PM
James92SE's Avatar
2 VE's are better than one!
I didnt even waste time getting the adjustable rear links on the back. The back doesnt nearly wear as bad with negative camber as the front (because the front tires do the pulling obviously). I just have camber bolts in the front and nothing in the back.
Especially with Eibachs the rear (and probably even the front) can be almost in spec with no camber correcting aftermarket stuff. My rears on Intrax are just barely out of spec. They dont even wear bad enough for me to mess with getting the adjustable rear link. The front is where you're gonna go through tires like crazy. With the bolts in the front I actually got all the negative camber out of the driver side and to like -.3 or something decent on the passenger side.
Old Jun 1, 2004 | 03:35 PM
2 tha MAX's Avatar
Will a camber kit help my middle CV joint not to bend and also will it help my tires to last longer cause the inside of my sidewall is wearing down again? Thanks
Old Jun 1, 2004 | 03:54 PM
James92SE's Avatar
It wont help the cv joint because the cv joint is like that since the car is lowered. It will help (or fix) the inside tire wear depending on how much negative camber you have...
Also fyi everybody the camber bolts are nowhere near a 'camber kit'.. camber bolts are kinda half-assed camber kits but unfortunately it's all we have available to us.
Old Jun 2, 2004 | 04:49 AM
mod or sell?
What you want, adjustable strut mounts?
Old Jun 2, 2004 | 05:40 AM
Thanks James and everybody else
Yeah I will buy probably just the front soon or just go to a shop and see what they say.
Posted by internetautomar - Yesterday at 12:10 PM
Always that good sells pitch. I still cant get the stupid window regulator I bought from you on but I just need to take off two more bolts and then im done.
Old Jun 2, 2004 | 06:12 AM
mod or sell?
phew, I was worried that there was a problem with the part.
at least it's an installer error
Old Jun 2, 2004 | 06:17 AM
2 tha MAX's Avatar
I cant seem to get your page to load, internetautomar. What is your prices for front and rear?
Old Jun 2, 2004 | 06:34 AM
mod or sell?
Ingalls:
Front Camber:
2 degrees adjustment bolts: I-81250 $20
1 degree adjustment bolts: 35410 $10
Rear Camber:
1 degree adjustment link Polyurethane Bushings: 38250 $43
1 degree adjustment link Rubber Bushings: 38270 $45
plus shipping
Old Jun 2, 2004 | 07:56 AM
bru91's Avatar
Maxima of the Month Dec. 07
I just bought camber bolts and links from internetautomar, he's got good prices.
Old Jun 2, 2004 | 08:16 AM
mod or sell?
thanks
I try
Old Jun 2, 2004 | 06:20 PM
Hornswoggler's Avatar
What are your current alignment settings without the kit, and what is your target alignment?
The reason I ask is because some suspension mods are for increasing the amount of negative camber rather than decrease it. Granted, you are trading tire wear for improved handling but negative camber is not always a bad thing.
Old Jun 2, 2004 | 08:30 PM
fugi43's Avatar
I think its +/-
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
