gauge not working
Old Jun 5, 2004 | 05:40 PM
pedal2dafloor's Avatar
gauge not working
the gauge that shows hot and cold isnt working can anyone tell me wat the problems is and how can i get it fixed
Old Jun 6, 2004 | 03:57 AM
CandiMan's Avatar
Say Candyman 5 times
Sounds like the wire came off the sender for the temp gauge. What engine do you have, maybe we can point you in the right direction.
MIKE
Old Jun 6, 2004 | 06:40 AM
im really new at this but i looked and it said v6 3000 is that the type,how else can i check?
Old Jun 6, 2004 | 06:43 AM
CandiMan's Avatar
Lets start with this, what year and model car do you have? You either have a VG or a VE engine.
All 89-91 SE and GXE had VG engines
All 92-94 GXE's also had VG engine
VE engines were only 92-94 SE's
MIKE
Old Jun 6, 2004 | 07:01 AM
89 SE GXE VG engine, ok thats mines. so wats the next step?
Old Jun 7, 2004 | 06:32 AM
grody's Avatar
OK, standing at the front of the car, you will look under the hood. You will see this big metal object with lots of hoses and wires. That's your engine. At the very top of your engine is the metal piece with the V6 3000 plate. That's your upper intake collector. Still standing at the front of the car, on the far left side of that there is a pipe coming off with two hoses coming out of it (actually, it comes off the intake manifold 2 pieces down from the upper collector. That's where your temp guage is. The temp guage is the one closer to you from where you're standing. The wire may have come off of it, in which case there will be a small terminal exposed, and a wire nearby that should slip on very easily. The other possibility is that the terminal broke off (like it did on mine). In that case, you'll need to get a wrench (I believe it's a 12mm or so), unscrew the old sensor, and screw in a new sensor.
Old Jun 10, 2004 | 02:32 PM
thank u so much
Old Jun 10, 2004 | 05:07 PM
Spipedong90's Avatar
Yeah, I'd check the hot and cold sensor on the engine.
Just messing with you.
If you need a photo or something of where the temp sender is, let me know.
Old Jun 10, 2004 | 05:13 PM
CandiMan's Avatar
From the looks of it, get your camera ready
MIKE
Old Jun 10, 2004 | 05:23 PM
jwmaxse's Avatar
It might just be corroded too, if it is just sand the connectors down and put some dielectric grease on it.
Old Jun 11, 2004 | 08:01 AM
grody's Avatar
MIKE
BWAHAHAHAHAHA
MAXSE5SPD
Sep 17, 2022 04:00 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
acw
Aug 13, 2015 12:50 AM
kenc15
Aug 5, 2015 08:29 AM
