A/T shifting hard.......really hard
Old Jun 7, 2004 | 01:34 PM
n1_saxman's Avatar
Ever since I changed to a pop-charger, my tranny is shifting a lot quicker and a lot harder. I know that shifting faster is much much better than shifting slowly, but can the car shift too hard and do damage? If so, what can I do?
Old Jun 7, 2004 | 04:06 PM
Scope's Avatar
Im izz sexay
I doubt it because the purpose of doing a VB mod is to reduce stress and to shift as hard as possible. By hard I mean you can sometimes hear a tire chirp BUT when it shifts you dont hear something banging against the engine.
Old Jun 7, 2004 | 04:34 PM
internetautomar's Avatar
mod or sell?
maybe you pinched a cable ?
Old Jun 7, 2004 | 06:36 PM
subs1000w's Avatar
proboly unpluged you drop resiter since i beleive its right under your the pop charger
Old Jun 7, 2004 | 08:51 PM
n1_saxman's Avatar
there is a definite "clack" of gears when I shift from P to R. Anyway, what do the connections look like on the drop resistor? BTW, I've noticed two wires each with a male connection on them like the jack on a pair of headphones. Could these be it or do I have another problem to solve?
Old Jun 8, 2004 | 08:52 AM
eric93SE's Avatar
That could very well be your dropping resistor. You WILL ruin the tranny if you don't fix the problem.
Old Jun 9, 2004 | 05:55 AM
n1_saxman's Avatar
So how do I fix it? Where should I slide or put the resisters in?
Old Jun 9, 2004 | 07:10 AM
eric93SE's Avatar
First verify that the dropping resistor is plugged in! then check all the other connectors in that area, MAFS, throttle positioning sensor...
you won't be "sliding anything or putting any resistors anywhere"
Check that your tranny fluid level is okay.
Old Jun 10, 2004 | 12:19 PM
DatSRBoi's Avatar
if it shifts too hard over a period of time i recommend u check it out again. becuz my car did it too and the gears are going to meet its tombstone soon...and sucks my baby got wreck by a f-150 2004...so its already in the shop muahahha
Old Jun 10, 2004 | 12:31 PM
n1_saxman's Avatar
where is the drop resistor located?
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
