Clear corner probs.
Old Jun 10, 2004 | 04:47 AM
3rdcharm's Avatar
Clear corner probs.
so i bought some clear corner lights from custommaxima.com for my white 93 falSE. They look great on the car the only problem is the right one dosent work at all. I changed the bulbs in it and it still wont come on. When i put the factory corner light back on it works but only the orange light works. Is this a problem with the light, fuse, wires, or what?
Old Jun 12, 2004 | 03:04 PM
goon9's Avatar
LOOK AT THE BOTTOM OF THE BULBS. Srry caps was stuck. notice wether there is 2 points or one.
I bought the wrong bulbs when i first got my clears.
Old Jun 12, 2004 | 03:35 PM
BML94GXE's Avatar
Maxima Withdrawl is real
could be a short in the wire and whenever u put the stock back in it is moved to the right way to make it work. thry putting the clear corner in and jiggiling the wires around a bit.
Old Jun 14, 2004 | 04:50 AM
3rdcharm's Avatar
ok now allof the parking lights and the gauge lights do not work at all. Only when i press on the brake they come on but as soon as i release it cuts off.
Old Jun 14, 2004 | 05:27 AM
internetautomar's Avatar
mod or sell?
Bad ground somewhere
Old Jun 14, 2004 | 05:42 AM
Matt93SE's Avatar
STFU n00b!
sounds like you blew a fuse screwing with it.. check for loose or shorted wires now.
Old Jun 14, 2004 | 07:49 AM
3rdcharm's Avatar
i checked all the fuses under the dash and they are fine, around what area of the car should i look for the wires. its really weird only the headlights, clock , cigg lighter, dome, and brake lights turn on. What do the brakes have to do with this. Why is it that when i step on the brake pedal the gauge and parking lights come back but as soon as i release it they cut back off. I know i need new brake pads. is that why im having this problem?
Old Jun 14, 2004 | 07:04 PM
avusblue92se's Avatar
I had the same problem. I pushed the bulbs in too far and they were no longer on the contacts. Just put them in until they slide in to place and use no force.
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Blkkn8
Sep 22, 2015 06:37 PM
