How Can I Get the Best Engine Performance on a '93 Maxima GXE?
Old Jun 12, 2004 | 06:32 AM
db_skate's Avatar
What cheap modifications can I make to my '93 Maxima GXE to increase the engine performance considerably? Also, I've seen some suspension kits for a '93 Maxima 'round the internet, what would you recommend?
Old Jun 12, 2004 | 08:29 AM
Nj93Vi3tMax's Avatar
cheap modification? adjust ur timing, remove the stock air box and replace it with an air intake. For suspension, go with intrax springs and KYB struts or tokico blue. But if you want to lower more then go with sprints. BTW, i'm gonna sell my sprints springs and replaced with intrax so if u them, make me an offer. thanks
Old Jun 12, 2004 | 08:59 AM
lophix's Avatar
what about eibach?
Before you start any "mods", start doing preventable maintenance. Fix/ replace any problems you have or any parts that are prone to fail if you have relatively high miles and most of the parts are original. I assume you've got your timing belt. water pump, tensioner taken care of...suspension and steering components are in good condition...etc. If you have an original tranny
= high miles, start saving for a rebuild. No use forking out all your cash for mods and then having basic maintenance issues later. I speak from previous experience.
Old Jun 12, 2004 | 09:15 AM
MrGone's Avatar
lophix
what good are mods if the car is running like crap or isnt in good condition.
Old Jun 12, 2004 | 12:34 PM
BML94GXE's Avatar
Maxima Withdrawl is real
can we make this a sticky, cause this is posted way too often
Old Jun 12, 2004 | 01:07 PM
Matt93SE's Avatar
STFU n00b!
there used to be some, until Bill went berzerk and deleted them all
Old Jun 12, 2004 | 03:33 PM
BML94GXE's Avatar
oh, well maybe we should re-invent the sticky, with a full list stuff, from simplest to hardest???? Just a thought, like list starting with pop charger and ending with full engine rebuild. just a thought.
Old Jun 13, 2004 | 09:50 AM
db_skate's Avatar
Okay, thanks guys. I'll consider replacing some old parts before I do anything!
Anyway, we're getting the alternator replaced Monday, and I plan on replacing the brakes/rotors/calipers etc. What b/r/c parts do you recommend for my 3rd gen. GXE?
Old Jun 13, 2004 | 10:05 AM
lophix's Avatar
any particular reason why you want to replace the calipers? Brembo blanks for rotors and axxis metal master I believe are favs here on the org.
Old Jun 13, 2004 | 01:32 PM
db_skate's Avatar
No real reason to replace the calipers. Just a thought. Anyway, I was told that I should replace my air box with an air intake, what do you recommend? (sorry 'bout all the questions!)
Old Jun 13, 2004 | 02:32 PM
Scope's Avatar
Im izz sexay
Intake will increase hp by about 5-8 CAI (cold air intake) will inrease it around 10-15. These are all just estimates so don't hold my ranges too seriously.
Old Jun 13, 2004 | 02:34 PM
db_skate's Avatar
Yeah, but I was asking what brands would you recommend by price and performance in thought.
Old Jun 13, 2004 | 02:52 PM
Scope's Avatar
Im izz sexay
Warspeed, you can even do the hybrid approach which is to use a 90-93 Accord's CAI. It will be a HAI for the VG but it is an intake. You can get it from ebay. Look for the Bomz CAI for the 90-93 Accord.
Old Jun 13, 2004 | 05:00 PM
db_skate's Avatar
Also, as for the rear brakes, I have drum brakes, not disc brakes. I can't really find any drum brake replacements...
Old Jun 13, 2004 | 05:29 PM
internetautomar's Avatar
mod or sell?
swap in a rear disc setup!
BTW I sell the new parts you'll need for the brakes
Old Jun 13, 2004 | 06:13 PM
lophix's Avatar
ahh crap. drums. with the rear disc conversion part. I even have the rear disc suspension setup if you want it Freaking heavy though. Together with internetautomar, we could make this dream a reality! *insert chords of angels here* aaaa...men....
Old Jun 14, 2004 | 09:39 AM
Scope's Avatar
Im izz sexay
How hard is the conversion? Is it for amateurs because I might want to do this.
Old Jun 14, 2004 | 09:55 AM
jaguax's Avatar
Hey! Drums rock! We never have to wash our rear wheels because of brake dust! So what if our cars don't stop. At least they are clean!
edit - it's kind of a big project to convert to disc. You need to remove the rear struts and replace them with SE struts... So you're gonna need spring compressors and everything. There is a link to a writeup somewhere, I forget where but I'm sure somebody will give you the link.
Old Jun 14, 2004 | 11:32 AM
db_skate's Avatar
Well, It seems that it would be easier to have an SE and install the GXE luxuries than to have a GXE and install SE performance... Oh well, the rear disc brakes look like a good idea, they do come stock on the SE right?
Old Jun 14, 2004 | 11:38 AM
Jeff92se's Avatar
I'm needing a caw
Actually it would be quite a bit harder to install the GXE goodies. ie.. touch keypads, auto climate controls, electric suspension etc...
Old Jun 14, 2004 | 11:41 AM
db_skate's Avatar
It depends on what all you're doing... anyway, I have a gxe, and I plan on giving it se performance...
Old Jun 14, 2004 | 11:47 AM
Jeff92se's Avatar
I'm needing a caw
Look at what the GXE has that the SE doesn't. Then think about how difficult transfering those systems over to the se.
SE performance? I assume an VG powered se. It's just springs/struts/swaybar. Even the rear disc swap is cake compared to transfering the keypad over.
Old Jun 14, 2004 | 12:05 PM
db_skate's Avatar
Yeah, the keypad would be the hardest definitely. But anyway, my main goals are to replace my dashboard(it's got holes in it), and make it perform like the SE although it's not. Also, I plan to change the gauges, but it's not that important.
Old Jun 16, 2004 | 11:44 AM
artythe3rd's Avatar
i have a 94 GXE and i have four wheel discs stock and i would recommend throwing a air intake a high flow cat and borla cat back exsaust system
Old Jun 16, 2004 | 11:52 AM
db_skate's Avatar
Well, first I'm planning on installing a hybrid Accord CAI, then I'll be replacing the rear drum brakes with disc brakes(hopefully if I get the money). I'll do other stuff when the time comes. As for the disc brakes, I'll probably be using Axxis Brake Pads for front & rear, and Brembo Replacement Rotors for front & rear also.
Old Jun 16, 2004 | 12:06 PM
mod or sell?
I sell those
Old Jun 16, 2004 | 02:22 PM
db_skate's Avatar
how much?
Is there a website?
Old Jun 16, 2004 | 04:41 PM
lophix's Avatar
...because you have abs.
Originally Posted by artythe3rd
i have a 94 GXE and i have four wheel discs stock ...
Old Jun 16, 2004 | 05:12 PM
DaKeG's Avatar
Gxse now that is what i'm talking about.
Rear disc and break lines, motor swap, suspension upgrade( shocks, springs, Sway bars), it can be done, oh yess it can be done. all i would like to know is what makes an R model. GXSER ya
Old Jun 17, 2004 | 05:14 AM
Matt93SE's Avatar
STFU n00b!
nothing makes an "R model".. nothing. period. This is a Maxima, not an Integra.
Old Jun 17, 2004 | 06:56 AM
Scope's Avatar
Im izz sexay
I'm lost WTF is a GXSE? Someone help out.
Old Jun 17, 2004 | 07:01 AM
indy650n00b's Avatar
I have a 94 GXE without ABS and i have 4 wheel disks.
EDIT: But then again the vin number on my car doesent work in any shop computer, and i had a suposed calif only trouble code.
Old Jun 17, 2004 | 07:32 AM
Jeff92se's Avatar
I'm needing a caw
It would be cool to see pics of your engine bay and rear discs. Maybe someone coverted it?
Old Jun 17, 2004 | 07:37 AM
Nope, my family has had the car scince new. My grandfather bought it in 94 in victoria BC, then when he lost his liscence for hitting a pedestrian (he had no depth peception). He gave the car to my mother, who drove it across the country to ontario (where it is now) in 1999 where my mom drove it until i got my liscence and now its mine.
I sec on the pics and ill load up what i have (i dont have any rear disk pics but i do have engine bay ones) The rear disk pics will have to wait until my brother gets home with my car.
Old Jun 17, 2004 | 07:40 AM
Jeff92se's Avatar
I'm needing a caw
Ah. Canadian maxima. hmm
Old Jun 17, 2004 | 07:42 AM
dash1
dash 2
Car 1
Car 2
engine bay1
Its really dirty in those pics, its a lot cleaner now but yeah the pics of the rear disks will have to wait until 3.
Old Jun 17, 2004 | 11:28 AM
Matt93SE's Avatar
STFU n00b!
Canadian is the only part you needed to mention.
All Canada spec 3rd gen Maximas have discs in the back, and I believe they don't have the stupid power seatbelts either. they also have emissions stuff a little more stringent than the regular US-spec maximas, so you might indeed have a problem with the codes.
Old Jun 17, 2004 | 11:59 AM
MrGone's Avatar
how much?
Is there a website?
Price, I'm not sure on because I'm not Brian.
Website, www.internetautomart.com
Brians account is currently not working because he tried to switch emails and the org is messed up, so he asked me to reply for him.
You can also send him an email at sales@internetautomart.com
Old Jun 17, 2004 | 01:53 PM
Matt93SE's Avatar
STFU n00b!
LOL!!
now Shawn is post whoring for Brian!
(you getting a commission, Shawn?)
Old Jun 17, 2004 | 04:46 PM
db_skate's Avatar
A question about Brian's site...(if you can answer) For brake pads/rotors/etc. there's also "generic" parts. Would those perform the same as the name-brand parts?
