New Excuse For The Window To Stop Working!
Old Jun 26, 2004 | 10:06 AM
VASHtheSTAMPEDE's Avatar
I have completely taken my regulator, motor, and window lifter out and tested each to see which one is the culprit and the motor seems to be working fine, i took the regulator apart and the grey spool inside is spinning freely. So i have come to the conclusion that it is not the actual mechanics that are messing up, but the circuit board under the control buttons. Any advise would be greatly appreciated in either fixing the problem or finding a replacement CB.
Holla!
Old Jun 26, 2004 | 10:08 AM
mtcookson's Avatar
try sanding the contacts down a little bit or get some electrical contact cleaner and try that. the contacts must just be dirty and in need of a good cleaning.
Old Jun 26, 2004 | 10:17 AM
«§»Craig B«§»'s Avatar
Try testing the motor and regulator. There is a two wire harness with blue wires close to the motor.
+12V to one wire and ground the other, it should go one way, switch the wires and it should go the other way
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
