Whitish Smoke from tail pipe
i have recently notice white smoke comming out of the tail pipe. and even when the engine warms up it still smokes. also i have noticed oil leaking drops on the ground where i park my car. around there oil filter is located. i have hard some thing with the anti freeze coolent. i have decidec to flush the radiator and add in some raditor anti leak stuff in it also. does any one thing it will help.
also what parts can i clean, change to better the emmisions on the car kuz it smells bad or is jus the smoke?
Brian
Originally Posted by therealgoon9
White smoke typical says that u have a head gasket leak. When that happens coolant breaches into the cylinders and creates a white smoke.
Brian
i know what could of caused it to have a problem like this. and if its the head gasket problem isnt the smoke suppoed to go away after while? like till it warms up or after like some minutes have passed.
Sometimes it can "go away", but it depends on how severe the problem is. For example, if the head is cracked, once the engine heats up it can temporarily seal the crack from expansion. It's possible for that to happen with a head gasket as well, but not as likely. Also depends somewhat on where the breach is- between cylinders, etc. If it does stop, it will only be temporary.
Either way, it needs to be fixed. If you are getting antifreeze in the oil, you will destroy your bearings eventually.
ok when i turned on the car 2day i didnt see almost ne somke. jus some smoke which was kinda hard to spot out. i also added about like 1/4 of a qurt of oil in yeasterday. and i jus checked to see if there was ne of the whitish stuff in the oil. but since it was all black i cant tell so now aym jus gona change the oil and the oil filter. can the problem be that there isnt enought oil in there so it caused the smoke?
ok when i changed the oil is was like black but i didnt notice ne whitish stuff in it. is there any way i can check exactly where the problem. i also noticed most of the time when it smokes it starts when the car warms up or that's when it gets relly worse. but now what can do i to fix this problem besices give it over to the garage.
ok aym a total newbie but there do i go to get the compression test thingy.
2day when i opened my radiatior car i noticed some of the fluid comming out o could that be only becuase i have flushed the whole thing and put new stuff in. eaiter way it was comming out but i closed it fast b4 a lot can come out. but again where can i go to get the them tests done.
internetautomar i notice u sell parts. u have tha parts i need rite. what parts do i need. because i would like save save more. pep boys said around 1200 + labor. and u got cheaper prices then them. can u please help with thisss..
i dunno yet havent had the change to take the car to pep boys. how moch is it to get the tests done if ne one knows?
aym hoping the parts you have are reliable and fit perfectly in the places they go into.
don't know what they charge for diagnoseing the car.
I've had no complaints on the fit or quality of my parts so far.
there are quite a few org members who'll tell you just how nice a guy I am
yo internetautomar by far u have the cheapest Gasket Head Set or the Head Set. Napa was like $330 pep boys jus plain said 1200 but there was 2 thing he added i think the set it self was like 345 and u have it for 250 which is way better then 330 or ne thing but then it all comes down to shiping hahaha.
and i tryed to see the compression kit thingy they siad i need the tq numbers and stuff for the bolts. if i get it is a newbie able to do this. and do any one got a write up for this? it be hot to have that.
You have to start somewhere, I just hope this isn't your only car.
You NEED to get an FSM if you plan on doing this yourself.
This is a BIG job, experienced or not. Be prepared to remove a TON of stuff, and it will take a while. It's not a 15 min. job....
BUT.. IAMart is right, you gotta start somewhere if you are going to work on your own car, so... at least get a Chiltons or Haynes manual, if not the actual FSM. You definitely don't want to be doing this blind.
One last comment- totally my opinion- you might want to do some more diagnostics and find out what exactly is going on before you start ripping stuff apart. I am 90% sure you've got a bad head gasket, but I'd want to know which bank it's on, etc...But that's just me.
nah this not our only car. we got like 3 Maxima's 93Se, 96GXE, 04Se.
but yeah i learn as i do stuff and rescearch hardcore b4 i actually do ne ting.but i have machanic who prolly gona do this for me. i jus wanna know which gasket is leakin left or rite b4 i spend more then i have to, but then if i jus buy the set and replace every thing i think it would be better in the long runn aym i rite or should i jus replace the broken one?
http://www.cardomain.com/id/southstar019
there's the link to my car domain site. jus the 4th gen maxima isnt there
If I were doing it myself, I MIGHT think about only doing the bad side, but then I don't always make the best decisions..
so i guess its a good idea to jus put new ones on both sides? or shoudl i look for a new VE engine kuz i have VTC troubles also but i add the Lucas engine oil stuff and the sound goes away. it sounds better then jus adding in the STP engine Oil treatment that i used to add. and i also have like 187,XXX miles on it. so is it better to get new head gasket or whole new engine?
Leaking oil around filter
I had, what I thought were leaks from the filter, yet it turned out to be the pressure sender. I tightened it up and the leaks stopped.
As for the white smoke , are you sure it's not signalling a new pope?
HerpDerp1919
Sep 29, 2015 02:02 PM
