Shift Lock
Old Jul 26, 2004 | 07:14 PM
spyhunter84's Avatar
Shift Lock
Maybe people have asked this before, but my shift lock doesnt work any more when i press the brake so i have to do it manually, so i was wondering if anyone has figured out how to fix it.
Old Jul 26, 2004 | 09:37 PM
rymo926's Avatar
break the white plastic that keeps it lock
Old Jul 27, 2004 | 04:03 AM
maxima76's Avatar
Do you mean that little button that you have to press down to move the gear selector?
Old Jul 27, 2004 | 08:54 AM
yea the little orange button, usually you just step on the brake and shift but mine you have to push the orange button
Old Jul 27, 2004 | 09:04 AM
Cincy94Max's Avatar
Generally this is due to a blown fuse. My mom's Camry wouldn't go in gear without depressing the shift lock because I had blown the fuse for the rear tail lights. No taillights = not safe, so the shift lock was activated. Check your fuses. The other idea the manual says is that the shift lock is activated on cars that have a low battery charge. Maybe have your battery checked out.
Old Jul 27, 2004 | 08:41 PM
rymo926's Avatar
The white piece is in side the plastic cover. remove the surround and you'll see a move-able white plastic piece, just that a pair of needle nose that rip it out. probelm fix.
Old Jul 27, 2004 | 08:51 PM
DMad8724's Avatar
have you done this yourself?
Old Jul 27, 2004 | 08:54 PM
DMad8724's Avatar
if anyone knows the wiring for this, and a way to bypass it that way, id be up for doing a write-up id rather not just mangle the system
Old Jul 27, 2004 | 09:07 PM
rymo926's Avatar
Yes, I had the same probelm, sometime works sometime don't.
Old Jul 29, 2004 | 04:26 AM
maxima76's Avatar
this might sound silly but where is the plastic cover do you mean the fuse box cover?
Old Jul 29, 2004 | 12:15 PM
rymo926's Avatar
the plastic that surround the shifter. it's a snap-on. there is a box/motor that moves a white plastic lock that keeps the shifter from moving. remove that plastic.
Old Jul 29, 2004 | 07:59 PM
JD's Avatar
JD
U have a bad switch.. There's two that can do it but more than likely just one bad. I had the same problems a few years back. Worked sporadically, then nothing at all. I used the little orange button for a while, then had it fixed when it was in for something else.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
