Timing belt questions
Old Jul 29, 2004 | 01:14 PM
dod.albino's Avatar
1) Do you really need a holder to remove the cam pulley or can you improvise with a screwdriver, strap wrench or other?
2) Do you really an installer to install the cam/crank seals or can you improvise or make your own?
Thx for replies
Old Jul 29, 2004 | 02:36 PM
Matt93SE's Avatar
STFU n00b!
Ummm, with all due respect... if you have to ask these questions, you should probably let a mechanic handle it.
the proper answer is no... just do whatever's necessary. when I pull the cam sprockets loose, I do it before removing the timing belt. I just leave a breaker bar on the crank pulley and pop the cam bolts loose, then snug them up so the pulleys don't wobble while I'm removing the belt.
for the seals, I just use big sockets the same size, or the old seal I pried out with a hammer. never had a problem.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
JMag90
Aug 25, 2015 09:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
