help removing/reinstalling moonroof shade??
Old Aug 6, 2004 | 09:28 AM
rzirker's Avatar
I need to swap an old, bent moonroof shade with a good one in another SE. I started kind of yanking on the old one to see if they maybe just snapped into the track. Didn't work and I don't want to force them.
Anyone out there done this before? What's the trick? I appreciate the help.
Old Sep 3, 2004 | 09:56 AM
lx4life's Avatar
thats a good damn question i would ike to know this also
Old Sep 26, 2004 | 06:25 PM
BOB-O's Avatar
Moon Roof
Did you get an answer or find out what to do? It's real easy, just gei inside, slide roof back and remove the cover on each side (right & left) then you can see the bolts holding the roof on. Remove them and lift the roof off. The slide then can be removed by sliding it forward and lifting it out. When you put the new onein, be sure it is in the correct track, it has to be in the one at the bottom or things will bind.
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
homeyclaus
Sep 3, 2015 06:15 PM
FanaticMadMax
Aug 21, 2015 05:59 PM
jashick
May 17, 2001 07:36 PM
