Problem when accellerating
Old Aug 28, 2004 | 11:26 AM
SouthStar019's Avatar
OK this morning i noticed when ever i step on the gas the car would(cant relly explain this but here i go ) it was like act like its humping sumthing. it like it speeds up for a second and stops and keep doing that. unless i gently( like extra gental) step on the gas pedal. i also replaced the fuel filter yeasterday. this also happned when i cleaned the throttle body but it went away after like 5 mins of driving at low reves. but this is taking even longer.
some one pleazee help meee.... thanksss
Old Aug 28, 2004 | 12:16 PM
Magnifico's Avatar
HAHA your description is funny as hell... acts like its humping something, haha
hm... maybe your MAF is dying... or maybe check your intake hoses and fuel pressure
Old Aug 28, 2004 | 12:34 PM
swowlinc's Avatar
1993 SE
Dont forget to change pcv valve. Made a noticeable diff to me.
Old Aug 28, 2004 | 12:45 PM
PCV valv? ermm must look for this..
Old Aug 28, 2004 | 12:49 PM
or count i have tighted the screws extra tight causing the openings to get smaller and so less fuel goes throu?.
Old Aug 28, 2004 | 01:06 PM
it wassss it wassss thanks for the help. but can the PCV valv help with that. what exactly is its job? (sorry for the newbi questions but this is how i lerns.
Old Aug 28, 2004 | 03:12 PM
acidspit86's Avatar
check your o2 sensor with a voltmeter, my car used to do the same thing
Old Aug 28, 2004 | 07:15 PM
and where do i find the 02 sensor?
Old Aug 28, 2004 | 08:13 PM
Ninty-two-se's Avatar
I had a similar problem in my 1992 SE... It turned out to be the coil packs... maybe get a friend with good coil packs and swap them in and see if that fixes it...
Old Aug 28, 2004 | 08:22 PM
goon9's Avatar
Timing could of slipped if it's a vg
Old Aug 29, 2004 | 07:40 AM
nope i have a 93 Se and aym the only one with a 93 se. none of my friends have one. aym the only one with a /\/\ /-\ X | /\/\ /-\.
Old Aug 29, 2004 | 11:25 AM
internetautomar's Avatar
mod or sell?
on the y pipe in front of the catalytic converter.
if it has over 60k on it replace it PERIOD!
Old Aug 29, 2004 | 12:02 PM
Cliff Clavin's Avatar
Way out West
Did you find the problem?
The most likely cause is going to be MAF or coil packs, although those aren't the only possibilities.
My car stalled/bucked (humped something ) on acceleration and it turned out that one of my rear coil packs was bad. I swapped in a lot of parts including ECU, cam sensor, ignitor, o2 sensor, throttle position sensor and MAF in trying to find the cause before I replaced the coil packs.
A lot of guys with VG engines have had their MAF or MAF harness cause this problem. It doesn't seem to occur as much with the VE for some reason. I also read where the cam position sensor caused stalling/bucking, but that was on a google search and as far as I know, no one on .org has verified this to happen.
I talked to a Nissan Tech a few months back and he said using non-OEM style spark plugs can also cause problems like this, particularly Bosch plugs.
When your o2 sensor craps out, you usually start getting worse gas mileage. I think some guys were getting around 200 miles to a tank, then by just replacing the 2 sensor it jumped up over 300 miles to a tank. I have yet to read where that caused anyone's car to stall or buck, however. Internetautomart is right. It should be replaced if it hasn't been in the last 60k.
Old Aug 30, 2004 | 12:35 PM
yeah i get poor gas milage i got like 90 miles on like half a tank. but any way ayma newbi. so is replacing the 02 sensor A job for me. if ther is s write up for it then i can prolly do it. i should invest in a FSM.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
