Tech Help Please !
Tech Help Please !
Ok i got a 92 maxima gxe and i was having some idle problems with it and also it some other things anyways ..
i hooked it up to a scanner today at the shop and it gave me 2 codes .
13 - Temperature Sensor .. THat i know and im replacing it .
And 34 - Detonation Sensor ......
Now i looked in to it and it turns out to be my knock sensor
so what i really need from you guys is the location of the knock sensor and the wiring diagram for it if you have on e.
and if any one has had to change this a little help would be appreciated .
Check the General Reference Links sticky thread - just passing along info, I haven't had the problem. Good luck.
knock sensor for the VG is on the back of the block, right behind the power steering pump area. it's sticking straight out from the block.
I've never seen one go bad on a VG engine, but they're very common to go out on the VE and VQ.
Ben2003GLE
Sep 24, 2015 04:25 PM
